-   -   Narrow Body RSR Style Build (http://forums.pelicanparts.com/porsche-911-technical-forum/1097577-narrow-body-rsr-style-build.html)
Antonov 06-21-2022 08:38 AM
I am in full support of this!
Originally Posted by Evan Fullerton (Post 11721921)
Really tempted to buy that GT3 Cup Motor on BAT today……
Evan Fullerton 10-01-2022 10:14 PM
Been a bit distracted over the summer with the boat and a project there to redo the backstay chainplate with some titanium. Shouldn't have any rust stains with this but it has been a real pain to polish. Still not done but a few more hours with the 600 grit and it will be ready for install.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/192E3FEC-8382-4C00-B9B9-7E704A17A377.jpeg?width=960&height=720&fit=bounds" alt="192E3FEC-8382-4C00-B9B9-7E704A17A377"/>
I have made some more progress with the car also. Got the inner fender wells finished up.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/ACEABEBF-ADA4-4FBB-8DAC-6A1F69264E73.jpeg?width=960&height=720&fit=bounds" alt="ACEABEBF-ADA4-4FBB-8DAC-6A1F69264E73"/>
Added an RSR dead pedal
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/8389EC96-6502-4F59-BE4D-4DE674553BDB.jpeg?width=960&height=720&fit=bounds" alt="8389EC96-6502-4F59-BE4D-4DE674553BDB"/>
Decided it needed to meet the dimple dies.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/03804238-8BD0-4D17-9343-F3C976A256D9.jpeg?width=960&height=720&fit=bounds" alt="03804238-8BD0-4D17-9343-F3C976A256D9"/>
And the inner footwell strengthening is done. A bit more work required down here though to fit the hybrid 993/911 pedal cluster I am working on and fit the battery in the smugglers box.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/F9881DEE-2904-4FF5-9F01-974CC5834683.jpeg?width=960&height=720&fit=bounds" alt="F9881DEE-2904-4FF5-9F01-974CC5834683"/>
and after 10 months waiting on diff parts, the trans is back from Tyson!
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/0973BBA5-D838-4088-B0C7-A6FBD7DF23A6.jpeg?width=960&height=720&fit=bounds" alt="0973BBA5-D838-4088-B0C7-A6FBD7DF23A6"/>
Guard diff went in, along with a billet shift fork, the billet side cover, steel/carbon synchro on 1-2 and new brass the rest of the way through. On advice from Tyson I am going to add a lube pump and GT3 filter for the gear oil to preserve the gears and bearings from the diff plate material.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/E19CE6AE-8C30-44D3-8593-982417158879.jpeg?width=960&height=720&fit=bounds" alt="E19CE6AE-8C30-44D3-8593-982417158879"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/476429DF-BDAD-42B4-90DD-C6948BB952CB.jpeg?width=960&height=720&fit=bounds" alt="476429DF-BDAD-42B4-90DD-C6948BB952CB"/>
Hopefully this g50 proves durable because it certainly isn't the light weight or budget option.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/5B19F721-7598-434C-963B-600CFBDF28E4.jpeg?width=960&height=720&fit=bounds" alt="5B19F721-7598-434C-963B-600CFBDF28E4"/>
Evan Fullerton 10-16-2022 08:38 PM
Started the modifications and fitting of the 993 oil tank.
Adapting everything to AN-16 fittings, remote 964 oil filter, through door jam filler, and normal early 911 thermostat that will be in the smuggler's box area.
Machined up a custom sleeve for the 993 drain plug that normally lives in the 993 thermostat. Should be pretty cool to have an o-ringed drain plug making it easy to drain the tank without getting any on your hand.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/EB98E795-14B7-49DF-A08C-C7B4EDEE283F.jpeg?width=960&height=720&fit=bounds" alt="EB98E795-14B7-49DF-A08C-C7B4EDEE283F"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/FC8EF899-FE5B-4AA2-9DB3-E7046185065C.jpeg?width=960&height=720&fit=bounds" alt="FC8EF899-FE5B-4AA2-9DB3-E7046185065C"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/69BEE94A-2E01-4164-B9A5-84BCA11866EA.jpeg?width=960&height=720&fit=bounds" alt="69BEE94A-2E01-4164-B9A5-84BCA11866EA"/>
Silver soldered into the tank.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/78C722F9-876D-475E-8E20-3F9ACC4565F7.jpeg?width=960&height=720&fit=bounds" alt="78C722F9-876D-475E-8E20-3F9ACC4565F7"/>
Original fill hole plugged and AN bung soldered onto the suction line outlet.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/284AF164-DB1F-488B-903E-445052B2FAEE.jpeg?width=960&height=720&fit=bounds" alt="284AF164-DB1F-488B-903E-445052B2FAEE"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/E3887E0E-34E0-4FBA-B47B-F7B3A3AEFC30.jpeg?width=960&height=720&fit=bounds" alt="E3887E0E-34E0-4FBA-B47B-F7B3A3AEFC30"/>
New filler cap fitting
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/2F910989-E55C-4285-B5E7-33048E3606A4.jpeg?width=960&height=720&fit=bounds" alt="2F910989-E55C-4285-B5E7-33048E3606A4"/>
Next step is to get it mounted permanently in the car to get the fame rail pass though hole in the right spot and fit the hole in the door jam before soldering in the new filler neck.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/C6AC47AF-0C7B-4CC2-B1A8-6DA0B2B2C58C.jpeg?width=960&height=720&fit=bounds" alt="C6AC47AF-0C7B-4CC2-B1A8-6DA0B2B2C58C"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/EA01B50E-CD09-45D0-8B35-2AE1D5180222.jpeg?width=960&height=720&fit=bounds" alt="EA01B50E-CD09-45D0-8B35-2AE1D5180222"/>
chrisbalich 10-17-2022 04:28 AM
Looks great!
I like the door-jamb-filler for the oil.
Evan Fullerton 09-24-2023 12:30 AM
Nearly another year has gone by, would you look at that. I have made a little progress though despite a wet winter and too many other distractions.
Now being at least half way to the other side of it, I don't recommend doing a 993 oil tank or at least how I have done it........... So much work.
Cut a big hole in the chassis.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_9865.jpeg?width=960&height=720&fit=bounds" alt="IMG_9865"/>
And then make it MUCH bigger.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/B12E9F87-1ECF-43DF-BFFB-7729888C5B74.jpeg?width=960&height=720&fit=bounds" alt="B12E9F87-1ECF-43DF-BFFB-7729888C5B74"/>
Fit some NASCAR boom tube exhaust tubing.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/E28DB22D-30EC-41B9-ACEF-00C9E2843A89.jpeg?width=960&height=720&fit=bounds" alt="E28DB22D-30EC-41B9-ACEF-00C9E2843A89"/>
Do a lot of welding
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_0396.jpeg?width=960&height=720&fit=bounds" alt="IMG_0396"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/1BCD88B0-D53F-4B34-9C90-2E5DB9BB09EE.jpeg?width=960&height=720&fit=bounds" alt="1BCD88B0-D53F-4B34-9C90-2E5DB9BB09EE"/>
Trim some more, make a hard line...... hey this might work!
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_0744.jpeg?width=960&height=720&fit=bounds" alt="IMG_0744"/>
Finish silver soldering on the new filler after aligning everything..... got to do this twice as I had it clocked incorrectly the first time. The cap has to be in the horizontal position to clear the door.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_9905.jpeg?width=960&height=720&fit=bounds" alt="IMG_9905"/>
Can't locate where to put the bulkhead fittings in the rear firewall without oil lines. So bend up some stainless tubing.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/70207569583_305445EB-CB75-4D9F-806D-2CBB5A4C90D2.jpeg?width=960&height=720&fit=bounds" alt="70207569583__305445EB-CB75-4D9F-806D-2CBB5A4C90D2"/>
But now to fit a full size battery in the smugglers box sideways gets tight..... do have to figure that out.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_1103.jpeg?width=960&height=720&fit=bounds" alt="IMG_1103"/>
Do some trimming on the Ebay battery box.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_0847.jpeg?width=960&height=720&fit=bounds" alt="IMG_0847"/>
Cut another giant hole.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_1504.jpeg?width=960&height=720&fit=bounds" alt="IMG_1504"/>
Make a metal shoe to fill the hole.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_1505.jpeg?width=960&height=720&fit=bounds" alt="IMG_1505"/>
Finally getting somewhere.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_2601.jpeg?width=960&height=720&fit=bounds" alt="IMG_2601"/>
Back on the other end finish messing with the 964 oil filter console bracket.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_2599.jpeg?width=960&height=720&fit=bounds" alt="IMG_2599"/>
And now I can almost go back to finishing closing up the back seat area that I cut out oh so long ago!
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/71720903288_25387733-2A8E-48B7-819A-38F3F1556891.jpeg?width=960&height=720&fit=bounds" alt="71720903288__25387733-2A8E-48B7-819A-38F3F1556891"/>
Evan Fullerton 11-11-2023 12:05 AM
Finally almost done with the torque tube and rear suspension mounts.
I do love me some dimple died holes.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/71839788736_730EDB5B-8D8C-4852-B612-D05A5B4F0698.jpeg?width=960&height=720&fit=bounds" alt="71839788736__730EDB5B-8D8C-4852-B612-D05A5B4F0698"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/71840311605_CC75E5D7-4807-4DD6-A695-400E127A8F11.jpeg?width=960&height=720&fit=bounds" alt="71840311605__CC75E5D7-4807-4DD6-A695-400E127A8F11"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_2693.jpeg?width=960&height=720&fit=bounds" alt="IMG_2693"/>
Soooo much welding.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_2716_egUaqpC2hPpqGUSYRU2gJS.jpeg?width=960&hei ght=720&fit=bounds" alt="IMG_2716"/>
Just to cut big access holes again.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_2819.jpeg?width=960&height=720&fit=bounds" alt="IMG_2819"/>
964 oil filter console fits still......... kinda.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_2891.jpeg?width=960&height=720&fit=bounds" alt="IMG_2891"/>
Rear seat delete panel round 2! Never underestimate how long it takes to trim and fit these panels and line up mounting holes........ it takes forever.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_2820.jpeg?width=960&height=720&fit=bounds" alt="IMG_2820"/>
Extra clerancing required.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/63CC646D-07C1-4C4E-9F80-34B38148607A.jpeg?width=960&height=720&fit=bounds" alt="63CC646D-07C1-4C4E-9F80-34B38148607A"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/360C9BCB-B9B0-4782-AC34-C0987A43D5AB.jpeg?width=960&height=720&fit=bounds" alt="360C9BCB-B9B0-4782-AC34-C0987A43D5AB"/>
Finally done....... pending some titanium pan head bolts........ and maybe a carbon kevlar skin on the aluminum panel to try and cut down on the tinniness of it a little.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_2894.jpeg?width=960&height=720&fit=bounds" alt="IMG_2894"/>
Mixed76 11-11-2023 06:19 AM
Make a few Xs with a bead roller to eliminate the tinnyness.
Sent from my Pixel 7 using Tapatalk
Evan Fullerton 12-03-2023 12:49 AM
Got myself some pin stands.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3017.jpeg?width=960&height=720&fit=bounds" alt="IMG_3017"/>
Had to make an extra long hole saw.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/72203113720_E94A840B-68BD-4DE7-9A49-6ADF786438F8.jpeg?width=960&height=720&fit=bounds" alt="72203113720__E94A840B-68BD-4DE7-9A49-6ADF786438F8"/>
Just a few layer to drill through.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/72203261524_7905DCFB-3BAE-4C91-BFFF-F8436888AEBE.jpeg?width=960&height=720&fit=bounds" alt="72203261524__7905DCFB-3BAE-4C91-BFFF-F8436888AEBE"/>
1.25 x .120 wall tubing goes in next.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3026.jpeg?width=960&height=720&fit=bounds" alt="IMG_3026"/>
Lots of welding later.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3029.jpeg?width=960&height=720&fit=bounds" alt="IMG_3029"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3073.jpeg?width=960&height=720&fit=bounds" alt="IMG_3073"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3076.jpeg?width=960&height=720&fit=bounds" alt="IMG_3076"/>
A little extra bracing on the rear ones.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3089.jpeg?width=960&height=720&fit=bounds" alt="IMG_3089"/>
Only slightly sketchy jacking on dirt.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3109.jpeg?width=960&height=720&fit=bounds" alt="IMG_3109"/>
This height sure makes working on the bottom of the car a lot nicer.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3111.jpeg?width=960&height=720&fit=bounds" alt="IMG_3111"/>
Evan Fullerton 12-03-2023 01:10 AM
Started filling dash holes. Going to go with an RSR style Perlon dash with no dash pad.
Might as well tie the X into the top of the glove box while it is accessible.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_2973.jpeg?width=960&height=720&fit=bounds" alt="IMG_2973"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_2976.jpeg?width=960&height=720&fit=bounds" alt="IMG_2976"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_2977.jpeg?width=960&height=720&fit=bounds" alt="IMG_2977"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_2980.jpeg?width=960&height=720&fit=bounds" alt="IMG_2980"/>
Drive train planning has also been going on. Have a couple clutch and flywheel options to choose from. Some interesting weight data.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_2993.jpeg?width=960&height=720&fit=bounds" alt="IMG_2993"/>
AASCO aluminum 3.6L flywheel 14lbs
964 RSR/ GT3 RS 4.0L flywheel 10.4lbs
Sprung hub semi metallic/kevlar clutch disk 6.2lbs
Unsprung 4 puck disk used in 993 GT2 and 996 Cups 2.2lbs
Might be a little rowdy with and unsprung puck disk but saving 4lbs off of the clutch disk is huge for reduced effort on what the synchros have to speed up slow down.
GT3 RS 4.0L pressure plate comes in at 9.4lbs. It has a steel friction surface unlike the plasma sprayed air cooled RSR pressure plate which I had in the car. Saving a little weight on the clutch disk but I think my total rotating mass will actually be almost identical to what was in the car before.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_2990.jpeg?width=960&height=720&fit=bounds" alt="IMG_2990"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_2988.jpeg?width=960&height=720&fit=bounds" alt="IMG_2988"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_2987.jpeg?width=960&height=720&fit=bounds" alt="IMG_2987"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_2996.jpeg?width=960&height=720&fit=bounds" alt="IMG_2996"/>
Evan Fullerton 03-04-2024 08:52 PM
Been some progress happening. Got the return for the oil tank welded in.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3113.jpeg?width=960&height=720&fit=bounds" alt="IMG_3113"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3117.jpeg?width=960&height=720&fit=bounds" alt="IMG_3117"/>
Fabricated supports for the passenger seat mounts.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3215.jpeg?width=960&height=720&fit=bounds" alt="IMG_3215"/>
Who doesn't like dimple dies!
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3240.jpeg?width=960&height=720&fit=bounds" alt="IMG_3240"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3243.jpeg?width=960&height=720&fit=bounds" alt="IMG_3243"/>
Got on the CAD one weekend and designed my own pedal box using Tilton 78 series master and a 900 series balance bar....... as is proving with most of the car, I am not the first to make any of these parts and it takes forever but I can actually get them. Trying to buy some of these not so standard bits has been quite painful so.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/2024-01-15_10-12-09.jpeg?width=960&height=720&fit=bounds" alt="2024-01-15_10-12-09"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3505.jpeg?width=960&height=720&fit=bounds" alt="IMG_3505"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3606.jpeg?width=960&height=720&fit=bounds" alt="IMG_3606"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3612.jpeg?width=960&height=720&fit=bounds" alt="IMG_3612"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3614.jpeg?width=960&height=720&fit=bounds" alt="IMG_3614"/>
Evan Fullerton 03-04-2024 09:04 PM
Dug the gearbox back out and test fit that again to work out the shifter.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3249.jpeg?width=960&height=720&fit=bounds" alt="IMG_3249"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3254.jpeg?width=960&height=720&fit=bounds" alt="IMG_3254"/>
On the long list of questionable decisions, cut some more holes in the car to fit the GPE Raised shift tower.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3269.jpeg?width=960&height=720&fit=bounds" alt="IMG_3269"/>
Had to section some off the end of it to fit around the inner seat belt mounts. This riser is designed to bring the shifter 4in back and 4in up........ so the shift rod also has to be shortened...... and the parking brake tubes...... and of course the shifter handle now need to have some of the curve taken out of it.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3245.jpeg?width=960&height=720&fit=bounds" alt="IMG_3245"/>
Shift rod shortened with 2in out of the front and 2in out of the back.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3647.jpeg?width=960&height=720&fit=bounds" alt="IMG_3647"/>
Machined up a straight shifter on a manual mill to try it out....... this shows the relative position of going 4in back and 4in up with the shifter base.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3351.jpeg?width=960&height=720&fit=bounds" alt="IMG_3351"/>
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3372.jpeg?width=960&height=720&fit=bounds" alt="IMG_3372"/>
Design was a go...... so I had one CNC machined, bead blasted, and anodized to fit a custom shift knob Dave Mason made me as a favor for making his first shift bushing prototype all those years ago.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3550.jpeg?width=960&height=720&fit=bounds" alt="IMG_3550"/>
Featuring the solid ebony knob Dave made me.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3551.jpeg?width=960&height=720&fit=bounds" alt="IMG_3551"/>
Reinforced where I cut out between the seat belt mounts with clearance for the now angled shift rod.
<img src="https://hosting.photobucket.com/images/u385/EvanFullerton/IMG_3437.jpeg?width=960&height=720&fit=bounds" alt="IMG_3437"/>
fanaudical 03-04-2024 10:12 PM
It's fun watching creating fab work - good job!
chrisbalich 03-05-2024 06:02 AM
Looking great, E!
I also had to section my tunnel riser to make way for the stock seatbelt anchors.
Evan Fullerton 03-05-2024 08:10 PM
Glad someone likes following along! Half my bad ideas came from this forum so happy for carry that torch forward.
Cory M 03-06-2024 10:48 AM
Great progress Evan! Love the rally stands. I've thought about making those too. The little tray on them is good to hold lug nuts. Shifter and pedals look good too. Full custom!
Antonov 03-08-2024 10:45 AM
Looking good. Love how the shifter turned out.
Evan Fullerton 09-25-2024 09:11 PM
Summer update.
Got the car up in the air and pulled the front suspension to start working on the inner fenders. It's a tight crowded space but you work with what you have.
<a href="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/11a47f5b-c645-4f37-a109-ce75dcebee99.jpeg?width=960&height=720&fit=bounds" target="_blank"><img src="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/11a47f5b-c645-4f37-a109-ce75dcebee99.jpeg?width=960&height=720&fit=bounds" alt="IMG_6008"/></a>
Time to fix the butchery what was the dealer installed AC and weld in the swaybar reinforcements. This car is getting a 28mm front bar and I have cracked two 914 chassis here so hopefully this keeps everything attached.
<a href="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/24e4c700-7053-4215-9bdf-623be2d5d645.jpeg?width=960&height=720&fit=bounds" target="_blank"><img src="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/24e4c700-7053-4215-9bdf-623be2d5d645.jpeg?width=960&height=720&fit=bounds" alt="IMG_6007"/></a>
<a href="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/b3e68c7e-bc66-4000-b1eb-91f7a5d9a7c4.jpeg?width=960&height=720&fit=bounds" target="_blank"><img src="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/b3e68c7e-bc66-4000-b1eb-91f7a5d9a7c4.jpeg?width=960&height=720&fit=bounds" alt="IMG_6011"/></a>
<a href="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/0d5537de-7f15-40c1-b813-ba742700d0c2.jpeg?width=960&height=720&fit=bounds" target="_blank"><img src="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/0d5537de-7f15-40c1-b813-ba742700d0c2.jpeg?width=960&height=720&fit=bounds" alt="IMG_6014"/></a>
While I am in here, time to delete the pinch weld on the shock tower as the tires hit it at full bump and don't want to cut down a tire.
<a href="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/b5be8fe3-8ee9-4a06-b032-59da637e514b.jpeg?width=960&height=720&fit=bounds" target="_blank"><img src="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/b5be8fe3-8ee9-4a06-b032-59da637e514b.jpeg?width=960&height=720&fit=bounds" alt="IMG_6020"/></a>
Now to do it all again on the other side!
<a href="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/d6c6730d-1252-4fd9-829f-a84323864b2c.jpeg?width=960&height=720&fit=bounds" target="_blank"><img src="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/d6c6730d-1252-4fd9-829f-a84323864b2c.jpeg?width=960&height=720&fit=bounds" alt="IMG_6021"/></a>
chrisbalich 09-27-2024 02:17 PM
Dang it! I never knew about this pinch weld delete/shave. May give that a go when the fenders come off next.
Keep going! Looking forward to the day this thing gets on track!
Evan Fullerton 09-27-2024 04:15 PM
I’m also looking forward to driving it one day, thanks for the encouragement Chris!
Your car the pinch weld may be a non-issue. Only really becomes an issue with lots of camber on wide high offset wheels with large diameter tires. I suspect with your new fenders, your tire is outside of the inner fender.
gled49 09-27-2024 05:04 PM
You're crazy, I love it.
Evan Fullerton 10-16-2024 12:42 AM
Air cooled 911 Race Car crazy I may be.
Been trying to get as much done as I can before starting a new job and move in a few weeks. Both of those will undoubtably slow things down again for a little bit.
As does still Autocrossing a buddies 914. Going to be a real disappointment if this 911 isn't significantly faster but always a possibility. Getting the 914 pretty dialed these days.
<iframe width="560" height="315" src="https://www.youtube.com/embed/-VBc-pKL-Mw?si=O6uSJ4cx_ARF8s6L" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
...... but back to the 911. Got the NOS Charlie bar installed. Nice to see some of the parts I have been collecting for the last 10+ years on the car!
<a href="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/dcf73d06-5770-4bfa-9d50-072483eb4d2c.heic?width=960&height=720&fit=bounds" target="_blank"><img src="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/dcf73d06-5770-4bfa-9d50-072483eb4d2c.heic?width=960&height=720&fit=bounds" alt="IMG_6069"/></a>
Started looking around at the front crossmember mounts...... always a dangerous thing and saw something that looked a little like a crack. So I took some more undercoating off to investigate and...... things escalated.
<a href="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/1a6365fe-9cca-4b01-9f02-148d9040716d.heic?width=960&height=720&fit=bounds" target="_blank"><img src="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/1a6365fe-9cca-4b01-9f02-148d9040716d.heic?width=960&height=720&fit=bounds" alt="IMG_6039"/></a>
Ended up adding some reinforcement and tying things in a little better to the cage. This thing is a tank at this point but when this build started the idea was to build it strong enough to survive the Targa Newfoundland rally soooooo onwards and upwards!
<a href="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/e2bd6be3-e38d-479c-8aed-ae55e3ce5ede.heic?width=960&height=720&fit=bounds" target="_blank"><img src="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/e2bd6be3-e38d-479c-8aed-ae55e3ce5ede.heic?width=960&height=720&fit=bounds" alt="IMG_6057"/></a>
<a href="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/410084a3-8786-47c1-92a1-9294857344f4.heic?width=960&height=720&fit=bounds" target="_blank"><img src="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/410084a3-8786-47c1-92a1-9294857344f4.heic?width=960&height=720&fit=bounds" alt="IMG_6058"/></a>
<a href="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/e6fed809-17ff-4f50-9bda-02adc04efa89.heic?width=960&height=720&fit=bounds" target="_blank"><img src="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/e6fed809-17ff-4f50-9bda-02adc04efa89.heic?width=960&height=720&fit=bounds" alt="IMG_6068"/></a>
While I'm in there....... might as well seam weld a few more things.
<a href="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/b63afd87-0fe2-4ea4-8727-acf96626ddd2.heic?width=960&height=720&fit=bounds" target="_blank"><img src="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/b63afd87-0fe2-4ea4-8727-acf96626ddd2.heic?width=960&height=720&fit=bounds" alt="IMG_6082"/></a>
Then onto oil cooler mounting. I am deleting the on engine cooler to maximize head and cylinder cooling with a 226mm fan....... in goes a CSF fender cooler and a big Setrab in the center hole........ and of course, custom brackets for everything.
<a href="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/05dc1a2e-57fe-4d14-b011-32d2e4327d72.heic?width=960&height=720&fit=bounds" target="_blank"><img src="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/05dc1a2e-57fe-4d14-b011-32d2e4327d72.heic?width=960&height=720&fit=bounds" alt="IMG_6089"/></a>
<a href="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/99be8309-f5a2-470e-8021-81a525af1f4b.jpeg?width=590&height=370&fit=bounds" target="_blank"><img src="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/99be8309-f5a2-470e-8021-81a525af1f4b.jpeg?width=590&height=370&fit=bounds" alt="IMG_6175"/></a>
<a href="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/d6096b41-a86e-4c70-af30-dff29a61ab5a.heic?width=590&height=370&fit=bounds" target="_blank"><img src="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/d6096b41-a86e-4c70-af30-dff29a61ab5a.heic?width=590&height=370&fit=bounds" alt="IMG_6174"/></a>
Next up..... build all the ducting for the center cooler to vent it out the fender wells.
Ryan_Cunningham 12-10-2024 02:24 PM
Wow. Just read this whole thread. Very cool. I am excited for updates!
It is also nice to know there are others out there have long term projects that don't get undivided attention. At least it makes me feel better!
Evan Fullerton 12-10-2024 11:58 PM
Thanks Ryan. Glad people are enjoying seeing my bad ideas. ;)
Speaking of bad ideas..... haven't gotten any work done on the car with the new house and job taking all my time but I have done a few things.
Had to modify my engine stand to make it telescopic. Used a piece of solid 2in aluminum bar stock to sleeve the leg.
<a href="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/f9edbb30-2cd7-45a9-88c8-ef4279418919.jpeg?width=960&height=720&fit=bounds" target="_blank"><img src="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/f9edbb30-2cd7-45a9-88c8-ef4279418919.jpeg?width=960&height=720&fit=bounds" alt="IMG_6487"/></a>
<a href="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/0e5a3593-0868-432d-8d2e-77a1cf4858d5.jpeg?width=960&height=720&fit=bounds" target="_blank"><img src="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/0e5a3593-0868-432d-8d2e-77a1cf4858d5.jpeg?width=960&height=720&fit=bounds" alt="IMG_6488"/></a>
........ and all that to achieve peak bachelor status. Hopefully can get the motor torn down and the case and crank off to the machine shop before the year is over. Staring at it every night and morning should be good motivation.
<a href="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/87234a5d-9487-4276-abb9-a98965f1c353.jpeg?width=960&height=720&fit=bounds" target="_blank"><img src="https://hosting.photobucket.com/5019d197-7b07-4674-9f24-50d85a64edb5/87234a5d-9487-4276-abb9-a98965f1c353.jpeg?width=960&height=720&fit=bounds" alt="IMG_6500"/></a>
Showdown 12-11-2024 03:44 AM
Approve. This is correct. ;)
