T77911S's Avatar
compression and cam timing.
just a bit of interesting info.
I changed my cam timing on my 930 this week end by .015, retarded.
my compression on number 4 was 130 before, it was 122 after.
just thought it was amazing at how much the compression changed with just such a small amount of cam timing change.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-12-2021, 07:09 AM
[QUOTE=T77911S;11389143]just a bit of interesting info.
Do you know why? Why not the other cyl in that bank at least.
Phil
Old 07-12-2021, 01:03 PM
T77911S's Avatar
I only compared 1 and 4 before I change the timing, then did the rest after.
it affected all cylinders,
RACE CAR:: sold
Old 07-13-2021, 09:03 AM
theiceman's Avatar
so are you telling us it was correct before and you intentionally retarded it ? or when you checked it , it was off from spec, so you corrected it ?
hard to tell what is going on from the limited info in your post.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 07-13-2021, 09:45 AM
T77911S's Avatar
no,
one side was off by .015. #1 had a compression of 120psi, #4 had 130. after #4 was 122.
point was changing cam timing by .015 changed the compression by 8psi.
I just thought it was interesting that the compression changed that much.
if my turbo was not in the way of the left side I might advance and retard the cams just to see how performance was.
RACE CAR:: sold
Old 07-13-2021, 10:55 AM
