Not enough room for master cylinder with aluminum front cross memeber
Hello fellow Pelican,
I need help with installing 23mm master cylinder on my 1971T with 911.341.101.01 aluminium front cross member.
I don’t t have enough room for the master cylinder.
Old 07-12-2021, 08:53 AM
theiceman's Avatar
looks like you might once its in and seated, may have to temporarily move cross member till you get master on the studs, otherwise its grinder time..
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 07-12-2021, 10:51 AM
Thank you for your guidance. Do you think anyone experience same issue?
Old 07-12-2021, 10:56 AM
Inlet lines would hit the bellow from turbo tie rods even if master cylinder is installed, so maybe needs smaller size master cylinder?
Old 07-12-2021, 11:04 AM
Bill Verburg's Avatar
They do fit, at least on a '76
here's mine
The other alternative is an '86 VW Corrado MC
Bill Verburg
Old 07-12-2021, 11:12 AM
Previously discussed and resolved here for install issues with a 23mm MC:
Bigger master cylinder problems - Pelican Parts Forums
Sherwood
Old 07-12-2021, 11:18 AM
Thank you all for help Pelicans!
I will try it as discussed.
Acey
Old 07-12-2021, 12:46 PM
