Clock falls out with phone mount
So I got one of those renn line phone mounts and it’s good. Except that now since it pulls the clock out slightly, the clock doesn’t seat correctly and it falls out. Anyone else having this issue
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250 |
Something is not right. Maybe improper installation? I have the clock, then the phone mount, then the rubber mounting ring. The whole assembly is then pressed into the clock hole. Press everything together. It holds very well.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! |
Rubber seal has to be behind the mount. I have them in 2 cars, no issues.
That might be it, I’ll have a look. Thanks
I have one in and SC and another in a 930. One of them is a little looser than the other. My guess is the seal on that one has shrunk a bit.
Been here a while
If everything else checks out, I’ve been known to run a few wraps of electrical tape on the clock under the rubber ring, the added pressure will tighten up the clock fit.
looking for 1972 911t motor XR584, S/N 6121622 |
I had the same issues with the Rennlist clock mount. Every time I nudged it or pulled the phone off, the gauge would pop out. Changed to a different mount.
Tony 1973 914 2.2 FAT Black 1974 911 Targa Lime Green 2018 Macan GTS White 2019 Targa GTS Agate Grey |
I have two of these in my cars. In my '70 the rubber seal is old and not as rubbery as the one in my 993. For the meantime I put some tape around the inside of the hole in the dash. You can't see it, but I'm ordering a new rubber ring as I'm sure that will fix the issue. Overall super happy with the phone mount (but I did modify to use an iPhone MagSafe charger instead)
'95 993 - daily run-about '70 911T - bringing her back to former glory |
Still here
Sorry but why is the clock on a phone mount in the first place ?
Didn’t come with any. I remember looking for them. Also didn’t see any on their website.
Here’s a link https://youtu.be/wnCImnAjMK4
love the guys phone case in that video , forget the clock mount i just want his case . lol
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
That's a better idea! I'm gong to do this today.
Full Send Society
A section of a MTB inner tube stretched over the clock body can also work in place of electrical tape. Just clean off the talc so it’s not slippery.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
My Rennline phone mount works fine. I'd try applying some tape as mentioned to get a new rubber gasket and give that a go.
Sold: 1989 3.2 coupe, 112k miles |
