911 + 129 = JOB
PDACPA's Avatar
1989 911 Driver Mirror spinning lose??
I went to fold my drivers mirror (flag style) into the car when I put it in the garage and heard a snap and now the mirror spins free. No locking in the position for driving.
Does anyone know what part broke or how to diagnose for repair?
Or is this a sign to get the newer round style!!
1989 911 Carrera Coupe 3.2
2012 BMW 135i M Sport
"It is not how much power you have, it is how much you have left to spare!"
Old 12-17-2003, 01:50 PM
It is easy to take the mirror off the car and take a look. There is a small (5mm?) allen bolt holding it on.
Old 12-17-2003, 01:52 PM
911 + 129 = JOB
PDACPA's Avatar
I will take a look at it when I get home. Didn't know if it was like the steering bushing where you knew exactly what part would have let go.
I imagine its something small, matter of figuring it out.
Old 12-17-2003, 02:12 PM
It is probly just the nut that keeps the spring tight that worked its way loose. They have a habit of doing that .
Jerry
Old 12-17-2003, 05:09 PM
911 + 129 = JOB
PDACPA's Avatar
Thanks will check it out.
Old 12-18-2003, 05:33 AM
jhm
Loose Mirror
This is an old thread, but what was the fix? I discovered my driver's side mirror was loose. I used an Allen wrench to disconnect the mount. I discovered the washer loose. I looked in my Bentley. It shows the parts... but no procedure or specs for tightening the washer or tightening the allen screw. It's a pcar. How can there be a pcar part without a torque setting? Do I just press the washer back on and hope for the best? It's been a long time when I quizzed Pelican. It appears the DIY mentors are leaving. Sad. Scary. Nickshu, any ideas?
JHMol
Everyone is a teacher. Everyone is a student.
Old 07-30-2021, 05:55 PM
8-9-10 on the parts diagram must have either come loose or snapped
Old 07-31-2021, 10:45 AM
jhm
Yes, part 8, the adjustable washer, is loose. It might just require muscle to squeeze it back on but I was looking for previous experience or instruction.
Old 07-31-2021, 11:43 AM
Designer King
Paulporsche's Avatar
I think I had to tighten the number 10 "guide tube". It takes either a large triple square or Torx (can't remember which) driver, so I just used a large slot screwdriver to turn it in.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-02-2021, 09:51 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
To clarify, because I'm kind of thick: Is the mirror spinning on the base, or is the entire assembly loose from the door?
If it's the former, it looks like spring tension from #9 is what holds the halves together, and so your two washers and threaded bolt would have to contain the spring. Do you have all those parts in your assembly? Are they doing what they should?
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 08-06-2021, 10:12 PM
jhm
Thanks. In the picture, the guide tube #10 might be threaded at the top. Does that screw into the mirror frame #1? And adjustable washers? How do they adjust?
Old 08-07-2021, 06:18 AM
jhm
The initial issue was the flag spinning on the mount. Once that problem is solved, tightening the mount shouldn’t be too difficult but I don’t see a torque setting… so “tighten” will be relative.
I have all the parts. They are not doing what they should.
Old 08-07-2021, 06:23 AM
This thread has a nice write-up.
Loose Mirror Tech Article
I had to clamp mine in a vice and make a holding jig to compress the spring.
Old 08-07-2021, 06:41 AM
jhm
Awesome. Thanks GH85Carrera! That’s what I was looking for.
Old 08-07-2021, 06:45 AM
Kraftwerk's Avatar
Just did this fix yesterday , super common issue it seems.
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 08-07-2021, 07:26 PM
jhm
Did you use the tech article? Any do/don’t s/hints?
Old 08-07-2021, 07:29 PM
Kraftwerk's Avatar
I actually didn't see the tech article until just now. The other day I stumbled across a short video of a guy fixing this same issue on mirrors of a 924 ( same exact mirror ) he took the mirror off the car but leaving it attached by the wires and then stuck a big flat-head screw driver in the hole where the wires go in and put the mirror together that way.. here it is:
https://www.youtube.com/watch?v=2pxP2m-Pn1c
It looks risky because you can damage the wires or the paint on the door, if not super careful. I was able to do it.. not super hard.
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 08-07-2021, 07:59 PM
jhm
Thanks. Knowledge is good.
Old 08-07-2021, 08:00 PM
Kraftwerk's Avatar
No worries, always glad to help, lord knows I have found so much good advice here. This is really a pretty great site still, thankfully. In all honesty I wouldn't be able to own my car w/ Pelican forums.
Thanks Pelican !
about two years ago one of the BMW M3 sites disappeared with ALL the old posts etc,. everything...it was a huge loss, so much information. : POOF gone. Really horrible tragedy, actually.
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 08-08-2021, 02:13 PM
jhm
Thanks Pelican !
Yep. With the Pelican brain trust I have repaired a couple issues well beyond my own abilities. Experience rules.
Old 08-08-2021, 07:34 PM
