Harpo's Avatar
rust repair
Mother nature has added some extra holes in my car that need to be plugged. These are the front right & left lower corners. As you can see the previous owner put a band aid on them for me.
Old 07-31-2021, 10:13 AM
Harpo's Avatar
I purchased this front clip from a forum member here. I want to avoid all the structural stuff like bumper brackets and the lower control arm mounts but not quite sure after that.
Old 07-31-2021, 10:21 AM
Harpo's Avatar
Little bit of rust, but fortunately just surface rust
Old 07-31-2021, 12:37 PM
Harpo's Avatar
test
Old 07-31-2021, 02:18 PM
Cars and Cappuccino
tdw28210's Avatar
test 2.(some weirdness going on with the forums)
Old 08-02-2021, 12:58 AM
Harpo's Avatar
Agreed but the fact that you just posted is promising
Old 08-02-2021, 11:37 AM
Harpo's Avatar
Yea it is fixed
So how do I cut up my donor front clip?
Old 08-02-2021, 05:36 PM
If you plan on cutting your car in the same that clip was cut, and welding the new clip on, that would likely be a really bad idea. You need to peel the onion, as it were, and stagger the joins; they cannot all be in the same plane. Likely that’s super obvious.
Best of luck, John
Old 08-02-2021, 05:45 PM
