930 muffler strap p/n differenes
The un-goobering of my car continues...
When I removed the Monty muffler from the car the other day, I noticed that the muffler strap had a pair of creases in it, effectively reducing the circumference slightly. Having never seen one before, I wondered if it was a factory kink to allow for thermal expansion or something of that sort.
Today when I started fitting my MM muffler, it became clear that the old strap wasn't going to fit with the kink in place.
(insert foreboding music)
Knowing the likely outcome, I nevertheless thought I'd try and un-kink it. To nobody's surprise this didn't work and the kinks simply fatigue-failed, so now I have a two-piece muffler strap.
The correct part number is 930-111-155-00, according to our host. But my former strap is a 930-111-175-00, which cross-refs to various 84+ Carrera 3.2 models, despite the '930' prefix in the part number.
So the question is if anyone knows the difference? It seems there might be a dimensional indication. The nominal diameter of the -155 version is 190mm I believe, but straightened out, they're clearly much longer than 155/175mm.
I also tried to find what strap size comes with the MM muffler when purchased new, but no luck there.
1990 928 GT, gone but not forgotten
1981 930, der Go Kart
Old 07-31-2021, 06:54 AM
