Porsche Crest Speedometer main shaft vibration
Hello,
I am wondering if someone has found a solution for the problem I am facing.
I have a 71 speedometer, with the cable to my 901 gearbox.
The cable connect in the speedometer to a shaft which has a sort of magnet flying-wheel on the other side.
The problem is that the shaft sometimes vibrate. There is a very little play, like if the shaft is too loose in his housing. There is a screw to press the flying-wheel against the main body but it doesn't help.
Did anyone encounter the problem ? Any idea how to solve it ? Any kind of bushing solution ?
Old 05-31-2022, 09:28 AM
Tags
speedometer issues
