jadracer68's Avatar
Speedometer Removal
Hi everyone,
My odometer stopped working and I'm trying to remove the speedo from the dash. There are three wires that go into the back of the gauge that I can't figure out how to disconnect. The other wires have the normal pull-off connectors on them, but these three are stumping me. Any suggestions?
Old 05-25-2012, 06:27 PM
schumicat's Avatar
those are light bulb sockets. you can pry them up with a knife edge. don't pull the wires.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 05-25-2012, 07:00 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Speedometer Removal.
Originally Posted by jadracer68 View Post
Hi everyone,
HINT:
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-26-2012, 02:09 AM
michael lang's Avatar
Patience in removing those is what saved me. Just slowly backing it out of the housing kept the harness from pulling out of the light socket. I also used a small piece of tape on each wire and numbered them. After the speedo was repaired and ready to go back in, I knew where to put the wires back to where they were disconnected.
Mike
'89 CARRERA
#402
Old 05-27-2012, 01:33 AM
No sleep 'til... BROOKLYN
flatsixjunky's Avatar
Good pic is worth a thousand words 86 911 Targa, thanks for posting. You can even see the production date stamped on the speedometer.
Take care guy's
-Orlando-
'89 3.2L G-50
'77 S w '79, 3.0L
'90 T-3 Syncro
32C #16
Old 05-27-2012, 01:47 AM
If I understand this correctly you have to pry the metal ring off the back of the speedometer, you don’t pull the red plastic pieces ?
Another question, what bulbs go in the speedometer? (1988 911 Cab)
TY in advance
Old 08-02-2021, 02:16 AM
pete3799's Avatar
Correct pry the metal part up. The plastic part will come out with it.
Pete
79 911SC RoW
Old 08-02-2021, 04:30 PM
Tags
speedo , speedometer , speedometer removal
