rust repair
Mother nature has added some extra holes in my car that need to be plugged. These are the front right & left lower corners. As you can see the previous owner put a band aid on them for me.
I purchased this front clip from a forum member here. I want to avoid all the structural stuff like bumper brackets and the lower control arm mounts but not quite sure after that.
Little bit of rust, but fortunately just surface rust
test
Cars and Cappuccino
test 2.(some weirdness going on with the forums)
Agreed but the fact that you just posted is promising
Yea it is fixed
So how do I cut up my donor front clip? |
If you plan on cutting your car in the same that clip was cut, and welding the new clip on, that would likely be a really bad idea. You need to peel the onion, as it were, and stagger the joins; they cannot all be in the same plane. Likely that’s super obvious.
Best of luck, John |
