Passenger side parking/running lights no workie
1986 turbo.
Passenger side fuse is #19.
With the fuse removed, I only see 10 volts coming to the fuse when the light switch is on.
If I put the fuse in, it drops to about 1 volt?
Driver side, #18, is fine, with 12 volts.
If I take power from #18 and supply it to #19, right and left will work.
Anybody have a WIRING diagram for this circuit?
I can't understand the factory CURRENT flow diagrams.
Lesser problem: Horn doesn't work and the fuse box cover does not show a fuse for the horn.
terry
1986 911 turbo - less than 30k miles
Old 08-03-2021, 06:02 AM
pete3799's Avatar
The horn uses a round black relay.
Pull the wire out of the fuse holder and check the voltage on just the wire. If not 12V Check voltage at the head light switch.
Pete
79 911SC RoW
Old 08-03-2021, 01:46 PM
kbruz's Avatar
I recall that a diode exists in the circuit for the passenger side. It’s up beneath the dash just above the key switch
kb
mercedes GLK350
2009 boxster s
86 targa
Old 08-03-2021, 02:20 PM
kbruz's Avatar
Parking light/blown fuse issue
Try this thread
kb
mercedes GLK350
2009 boxster s
86 targa
Old 08-03-2021, 02:24 PM
Thanks kbruz, that thread is very interesting!
I also had the rear bumper off recently, so I will check wiring back there.
Old 08-04-2021, 04:48 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Diode.
This might help.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-04-2021, 06:51 AM
Gerry,
Where do you get these schematics?
All I have are current flow diagrams, which make no sense to me.
terry
Old 08-04-2021, 07:02 AM
Ckt
That schematic is from my factory manual.
pm me if you need help with the diode.
G.
1986 911 Targa.
Only in L.A.:
Old 08-04-2021, 08:19 AM
After a bit of probing...
- My license plate lights are ON when the light switch is in the first position out on the switch. Discussion above said the diode should prevent that?
- disconnected the diode and still no right side parking/running lights
- I jumped around the diode and the lights work!
- With this jumper in place, I see 12v at #19 fuse. Before, only 10v was coming from the switch to the fuse panel and it dropped to less than 1v with the fuse is in place.
So, Gerry, aka '86 911 Targa', might be proud of me?
I dragged my multi-meter out and tested the diode.
It reads 0L both ways across the diode (reversing the leads).
According to google, this indicates a bad diode.
Time for a new diode!
Old 08-04-2021, 10:59 AM
kbruz's Avatar
The diode part is no longer available from Porsche. My mechanic just happen to have one in stock so was lucky. About 2 years ago I emailed the manufacturer of the diode (in Austria as I recall) and they were not much help. Could not cross reference to the Porsche part number.
Lastly if you search this forum you will find others have just bypassed the diode with no problem. The odd thing is that the 1987 schematic looks the same as 1986. But the 1986 is the only model year with this component. Not sure why.
kb
mercedes GLK350
2009 boxster s
86 targa
Old 08-05-2021, 06:04 AM
I called around and found the replacement part from Porsche.
Actually, you need the diode and the plastic 'holder'.
Diode - 91161710801
Holder - 825971990
Roughly $39 with shipping from https://www.porscheatlantaperimeterparts.com
Old 08-05-2021, 10:38 AM
