SHOOT! I meant to say "pressure plate" above and not "flywheel." (Although, I still think one can easily go with either with no ill effect.)
So, instead of this... "As a result, I think you could pretty easily go with just the lightweight *flywheel* without any issues." ...I meant to say this... "As a result, I think you could pretty easily go with just the lightweight "pressure plate" without any issues." Ugh. Did you end up going with the rubber centered clutch disc? |
| All times are GMT -8. The time now is 10:13 PM. |
