Slop in steering wheel
Hi Guys, Just finished a 500 mi trip in my SC and it ran flawlessly (would have enjoyed a/c though) and I've just noticed up and down slop in the steering wheel.
Where should I start looking to correct this? Is this accessed directly under the dash in the car or under the frunk area? I'll be giving this job to my mechanic but I'd like to know a bit more of what's involved so I have a better understanding of what he has to do. Thx |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Bushing.
search steering wheel bushing. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
There's a bushing just under the steering wheel that is a common point of failure. Rennline makes an easy to install replacement. From there, there is a bearing and a U joint under the Frunk, then the rack itself which is connected under the car.
RETIRED
Plastic bushing, common fail. Easy fix.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
it has been here not to long ago -this subject.Do some reading and make your choice;-)how do you want to fix it...
Ivan https://forums.pelicanparts.com/porsche-911-technical-forum/1090830-steering-bushing.html
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Thanks guys, looks simple enough that I will attempt the installation myself.
Not having much luck locating the bearing on the Rennline site but I'll keep trying. Thx. |
a.k.a. G-man
If it is only up and down, I would check the bolts holding your steering column in place too.
Сидеть, ложь, Переворачиваться |
You'll need a 27mm wrench for the big steering wheel nut.
