-   -   Install front IROC bumper custom grill X-Faktory (http://forums.pelicanparts.com/porsche-911-technical-forum/1100070-install-front-iroc-bumper-custom-grill-x-faktory.html)
shawn908 08-15-2021 12:09 PM
I recently installed an IROC front bumper (and a rear FG bumper) I purchased from a NJ Pelican. Bumper was a good fit but had challenges (fabrication of attachment points, for example).
Called X-Faktory to inquire about a matching grill for the oil cooler vent opening. Intend to install a front cooler at some point so until then, and maybe after a cooler is installed, (have to search that) using this grill, which matches material used in other grills available from X-Faktory.
Here's a few photos showing install method. Any suggestions to improve it or alternate methods to mount welcome.
To attach, made 6 "customized" hardware store L brackets. Made one hole oblong to allow for line up of bolt going through grill from front. And shortened one side cuz they were too long to start. Used a grinder.
http://forums.pelicanparts.com/uploa...1629052279.jpg
Back side attachment and front views, installed
Detail of attachment as seen from the front. Washers could be black I suppose. But these were available in the garage.
http://forums.pelicanparts.com/uploa...1629052279.JPG
This was during a test drive on local PA roads, some smooth and some not so smooth.
So good to get the car back on the road and enjoy it.
The grill stayed in place - no movement.
Knockdown 08-16-2021 12:26 AM
That turned out nice!
al lkosmal 08-16-2021 09:29 AM
Nice install Shawn and thanks for posting!
regards,
al
Geneman 08-16-2021 01:56 PM
Very nice job.!!
Al. do you sell this grill material such that i could order some a bit oversize and cut to fit. mine is a shortened IROC bumper to fit a 74RSR race car.
Thanks. FRank
al lkosmal 08-16-2021 01:59 PM
Frank, i don't really sell the material, but if you were to email me the dimensions, or better yet, provide a template, i could certainly make one for you.
regards,
al
Geneman 08-16-2021 02:21 PM
THanks Al. that would be great. let me a both measure and also see if i can get this mounted from behind like shawn did... without having to take apart my splitter. standby ... i also emailed you..
cheers frank
Geneman 08-16-2021 02:25 PM
Shawn. apologies for hijackjing your thread. where in philly are you? I am in Wayne on mainline. BTW my car is also sporting a black CF hood like yours!
shawn908 08-16-2021 04:30 PM
Frank - no problem! Comments good. I’m also on the Main Line - exploring Chester County roads and local C&C (Chester Springs, West Chester). I wish that hood was CF (as I seek to make the car lighter…) but it’s FG - still lighter vs steel.
