BAT industries Mocal oil cooler
Hello
Just installed one of these BAT industries 19 row 'B' kits in the front fender and it works great. Question is does anyone have any ideas for a stone guard that would fit? Hoping to buy something vs fab something up if possible
-J
1977 911S(c) with an 81 SC engine Anthrazite grey metallic
1979 911SC Coupe in Sky Blue - SOLD
1976 911S Widebody Targa - SOLD
Old 08-19-2021, 10:42 AM
I never really found a pre-made stone guard for mine. I fabbed one with a couple layers of hardware cloth.
Old 08-19-2021, 08:07 PM
I have has good results from my Mocal cooler. I had to make a shroud from aluminum sheet as I could not find anything pre made.
Old 08-19-2021, 08:09 PM
Understood, I’ll see what I can figure out
Old 08-19-2021, 10:11 PM
Uncertifiable!!!
Uwon's Avatar
Got a fender liner from the junk ward, cut it up and made a couple of brackets.
Cheers,
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 08-20-2021, 04:33 AM
7783911's Avatar
johan, your approach seems to detract from the cooling as it precludes air flow? If you driled a series of small holes into the liner wouldnt that improve cooling?
Old 08-20-2021, 05:56 AM
I'd like to fab something better than what I currently have, which is heavy duty wire mesh and some aluminum flat stock.
Old 08-20-2021, 06:20 AM
Zaz Zaz is offline
When I did mine I was looking for something temporary and found that the metal “EZ gutter guard” I had recently installed at my house fit perfectly - right width and slightly concave. Though only meant to be temp it’s been on for 4 years now- going strong.
74 911 Coupe
74 Triumph TR6
97 Jaguar XJ6
Old 08-20-2021, 07:07 AM
This is my factory stone guard. As you can see there is a rubber and foam seal for the fender to force all the air to go through the cooler, and not around it. That is very important for the cooling.
My car is a 1985 and it of course had the Carrera cooler, but no fan. My hoses were both weeping, so I bought new hoses, a new seal, and removed everything, added a fan, and a power source, and reassembled. Getting the hoses back on straight and not cross threaded is the trick part. And then getting the ends tight enough to not leak is the strength challenge.
Old 08-20-2021, 07:26 AM
Pretty much what's on mine, with some shrouding to help guide the air through the cooler and not around.
With track use, it gets absolutely hammered.
Very cool!
Old 08-20-2021, 01:41 PM
Uncertifiable!!!
Uwon's Avatar
I have a push Mocal fan in front and about 4” of clear space between the cooler and the stone guard. Both the cooler and fan are angled slightly downward so the air is deflected downward by the guard. It provides plenty cooling in stop and go traffic in hot weather. The solid guard keeps all the road crap from caking on to the cooler.
Johan
Old 08-20-2021, 07:49 PM
