Brake Fluid shelf life
I need to flush my brakes fairly soon and found an unopened can of ATE Super Blue on my garage shelf. Guessing it's 5-10 years old. Is it still good to use or does is separate or break down over time? Never opened so not worried about moisture contamination.
Thoughts???
'87 911 Carrera Coupe (go fast, small parts / small kids hauler) '04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius") |
There are millions of 10 to 30 year old cars on the road with the factory fill of brake fluid in them. If your can is factory sealed, used it.
I change my brake fluid every single spring.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Probably fine. But considering that a liter of ATE Typ 200 is less than 20 bucks, you have to ask yourself...do you feel lucky?
I wouldn't, even if it is fine.
I'd use it in a heartbeat.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
hygroscopic !! hygroscopic !! hygroscopic !! Blah blah blah.
I bought a new bottle of ATE in 2017 for a 911 track day. Used the same opened bottle again in 2018 for a 911 track day. Used that same opened bottle for 2 commuter cars in 2019. No problems. There's still some left. I'll use it as cooking oil. As Glen said, there are cars on the road with 20 year old brake fluid with zero issues. I would love for you to use the 10 year old bottle, carefully drive around the block, and possibly bust some internet myths.
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 09-30-2021 at 02:13 PM.. |
no brainer --use it...i just did in january ..it`s 12 years old and i`m still around driving it;-)
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 09-30-2021 at 04:41 PM.. |
For what it's worth I have an opened one that is at least 10 years old.
Now I don't put it in any of my cars or motorcycles but I recently used it to solve a brake fade issue on my disc brake mountain bike which had the original fluid in there from new, 2008...
cheers, Phil 84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies. |
Driver
Unopened can: I would be willing to use it.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Blue brake fluid. How retro! Use it. Amaze the Cars & Coffee guys.
But don't confuse it with window washer fluid. |
Put it on flea bay or bringatrailer.com. Set a $1000 reserve.
It's a 914 ...
I had the exact same experience, and used it on the racecar. I’d have to be convinced that a vacuum sealed container could somehow allow moisture to get in.
Decision made... I'm gonna use it !!!
Eng-o-neer
:d:d:d:d
Racing Blue, that's vintage!
Personally I would save it unopened and get some new Typ 200 for the car.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Now, I'm not advocating that a can of brake fluid should be part of your retirement portfolio, but they are selling for $75 on FleeBay...and empty cans for $14
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic |
People will collect anything. I have a few cans myself, I even have a few cans of Castrol R! That stuff smells glorious, reminds me of going to F1 races in the 60's.
I used it in My Elsinore 2cycle dirt bike.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
It's a 914 ...
Diss Member
The early gray rectangular cans or the later square blue cans?
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
