-   -   Removing rear seats-Can't get large screws off (http://forums.pelicanparts.com/porsche-911-technical-forum/110138-removing-rear-seats-cant-get-large-screws-off.html)
Dave Ploss 05-10-2003 03:27 AM
I'm trying to take out the rear seats. The backs are a problem as I can't move the large screws holding them in. I put a little pb blaster on them. I've tried screw drivers (not big enough), a flattened washer ( bent it) and nothing worked.
Any help in getting these loose would be appreciated. I don't want to use the equivalent of a BFH on these.
Thanks.
Dave
RoninLB 05-10-2003 05:30 AM
mine were also on very tight.. I think the thread gets weathered from under the tub.. I used a 1/2in socket screwdriver. I used another large screwdriver and baby sledge to slam the screw a few times first...........Ron
APKhaos 05-10-2003 06:40 AM
Dave,
These screws are notorious - most are frozen, for some strange reason.
An impact driver saved me - $25 Husky tool from Home Depot.
DByers 05-10-2003 07:03 AM
I had the same problem with mine. Once I had them out I went to a local specialty tool shop and spent .50 for some new ones with allen heads. Works much better now.
Doug Zielke 05-10-2003 07:57 AM
Soak 'em with a little PB Blaster, and then use the m/c impact driver as mentioned above.
Chuck Moreland 05-10-2003 08:01 AM
The problem is getting enough torque. Here is a way to do it with tools you probably already have.
Firstly you need a really big flat blade screw driver. Put the blade in the screw head. Then take an adjustable wrench and snug it down on the flat blade, like a "T" handle. Crank away.
evren 05-10-2003 08:48 AM
What Chuck said, worked for me a few weeks ago.
Dave Ploss 05-10-2003 10:07 AM
Guys,
Thanks alot. Most times you think you are the only one that had a problem like this. I know I'm not alone.
Dave
jakermc 05-10-2003 11:26 AM
A good tool for this is a drag link socket. Its basically a socket driver with a large flat head screwdriver bit on the end. It allows you to use your socket wrench and all its torque to get the bolt out. I couldn't remove mine either, used the right tool, and out it came. You can pick one up at Craftsman.com. Most stores will not stock it.
Randy Webb 05-10-2003 04:17 PM
Yes, also you can gind the drag link socket to fit the slot exactly. Then use impact or make own impact with a hammer.
