Speed Sensor Unit 89 Carrera Question
I'm trying to troubleshoot speedometer issue. My speedometer/odometer does not work. After reading several similar posts, I decided to replace the speed sensor at the transaxle. I ordered the part from Pelican, but it doesn't look like the unit in the car, Am I looking in the correct place? (see pictures)http://forums.pelicanparts.com/uploa...1630693852.JPG
http://forums.pelicanparts.com/uploa...1630693852.JPG Right (passenger) side of transaxle. I could barely get camera in area to take photo. Car is on jack stands. |
Maybe I'm looking at the back up light switch. If so, where's the speed impulse sensor?
Sensor/s location.......
Remove the left rear tire and you will find the reference and speed sensors by the transmission bell housing. Follow the two (2) black cables to the sensors.
Tony |
Thank you. Will do first thing tomorrow morning. :)
The speedo sensor plugs into the left side of the trans to the front of the drive flange. That works the speedo, if the speedo works. Follow the wire.
| All times are GMT -8. The time now is 08:51 PM. |
