Battery not Charging…. Brushes bad?
Hi everyone,
Car is 1989 911 Carrera 3.2, rebuilt to 3.4 by me about 2K miles ago. Need help diagnosing no charge condition. I have read quite a few threads. To cut to chase, does the pic of my brushes show them as suspect? The detail:
So actually have a couple of questions: 1. Do my brushes look like they could potentially be the problem? 2. Is there any way to test the alternator at an auto parts store without removing it from the fan housing? I assume not from the videos I have seen. 3. Is there a way to test alternator vs. voltage regulator separately, versus the assembly Thanks! Mark
1989 911 Carrera 3.2 2009 Audi A4 2.0TQA 2017 BMW X3 2007 BMW 328xi 1971 BMW R60/5 |
Follow up post:
I was able to remove the alternator from the fan housing using the John Walker method. Worked great. Took the alternator to Oreillys where they said it wouldn’t come up in their computer on how to test. Also I would need to have a pulley installed. Went to NAPA where they said the connections on the computer screen looked different than the back of my Bosch unit. Strike 2. Where have people successfully had their alternators tested? We have 2 rebuild companies nearby, but both said they wouldn’t be able to test for several weeks. Ugghhh. I hate throwing parts at a problem as a troubleshooting method but maybe I should just install a new voltage regulator. Will wait to see if forum has other ideas or advice on testing the alternator. Thx Mark
Voltage regulator, brush assembly is cheapish. An alternator rebuild shop can check it. Look for auto electric starter rebuild shop in your area. Take the pulley parts
leave it on the car and have it tested that way in the future.
its amazing what all they can test now, even the starter with it installed.
Hi everyone,
Just to close out the thread, my charging issues are resolved. I ended up buying a new voltage regulator from host, installing, and cleaned up pin 13 on main engine compartment connector (blue wire). I believe the VR was root cause, but of course can’t positively confirm without A/B’ing with old and new. Prior to install, I took alternator assembly to Generator Specialty on Rice Street in Minneapolis and they tested on a really nice dedicated bench. Could see wave form, voltage, etc. showed 14.2 volts. I bought a Cigarette lighter voltmeter from Amazon, and am pretty happy with it. Pic below. Thanks for the feedback and support. Mark
