-   -   Which Way is Up? (http://forums.pelicanparts.com/porsche-911-technical-forum/1101722-way-up.html)
Paulporsche 09-06-2021 06:38 PM
Which Way is Up?
If you look at the 2 pics of the sunroof guide plate you will see that one way shows a more or less straight side on top with the 2 small holes, and a dipped side that protrudes downward.
In the other you will see that it is inverted, ie the straighter side with the 2 small holes facing downward and the bent side faces up. This is the part that slides with the sunroof panel along the stationary side rails.
Which way is correct when mounted in the car? I think the bent side is on the bottom, and the side with the 2 small holes is on top, but I'm not sure.
This is for G Model cars.http://forums.pelicanparts.com/uploa...1630978391.jpg
http://forums.pelicanparts.com/uploa...1630978595.jpg
proporsche 09-07-2021 12:32 AM
yup, holes on top;-)
Ivan
Paulporsche 09-07-2021 07:02 AM
Thank you Ivan.
