Designer King
Paulporsche's Avatar
Which Way is Up?
If you look at the 2 pics of the sunroof guide plate you will see that one way shows a more or less straight side on top with the 2 small holes, and a dipped side that protrudes downward.
In the other you will see that it is inverted, ie the straighter side with the 2 small holes facing downward and the bent side faces up. This is the part that slides with the sunroof panel along the stationary side rails.
Which way is correct when mounted in the car? I think the bent side is on the bottom, and the side with the 2 small holes is on top, but I'm not sure.
This is for G Model cars.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-06-2021, 06:38 PM
proporsche's Avatar
yup, holes on top;-)
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 09-07-2021, 12:32 AM
Designer King
Thank you Ivan.
Paul
Old 09-07-2021, 07:02 AM
