Simple MSD Question
Hello,
Can an MSD 6AL be mounted under the drivers seat?
Is the length of run for the coil and distributor wires too long from there?
Cheers,
Frank
76 911S
Land Rover 110 Defender
Old 09-06-2021, 11:02 PM
Racer
winders's Avatar
Yes, you can run longer wires. But, MSD says to go a gauge up in size if you do so. In other words, use thicker wires.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 09-06-2021, 11:17 PM
Done!
Thank you.
76 911S
Old 09-07-2021, 12:48 AM
Racer
winders's Avatar
I would make sure no other wires are run parallel to the MSD wires as they carry a lot of voltage and will most likely create a lot of EMI....
Scott Winders
PCA GT3 #3
Old 09-07-2021, 01:12 AM
Have you any idea of the separation requirements? Eventually I'll be running Megasquirt from under the seat as well.
76 911S
Old 09-07-2021, 03:30 AM
Mahler9th's Avatar
Basic wiring considerations are applicable here. I have seen plenty of MSD installations in the floor area of 911's near or under seats.
Likely the biggest thing to be concerned from a noise standpoint is the trigger wire.
https://www.holley.com/products/electrical/harnesses/parts/8862
I doubt any can say what the "separation requirements" are from a quantitative standpoint.
In my experience, "good judgment" reigns supreme here.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 09-07-2021, 08:44 AM
Racer
winders's Avatar
The trigger is most affected by EMI which is why it is shielded. The wire from the MSD to the coil carries high voltage and is likely to generate the most EMI. When I ran dual MSD ignitions, I had to run the trigger wire away from other wires to keep its signal intact. I was able to run the coil wires in my main harness without issue. But, I did not have any sophisticated sensors that are affected by EMI in my EFI setup.
Scott Winders
PCA GT3 #3
Old 09-07-2021, 10:04 AM
Thank you both for the info.
So the trigger wire is the white one from the distributor?
So I'll use shielded wire to extend that one and keep it away from everything else.
Might mount the MSD under the left seat and the Megasquirt under the right seat.
Sounds like a plan.
76 911S
Old 09-07-2021, 03:50 PM
If you are using points, then you don’t need to shield the trigger wire. The signal wires that Scott is talking about is for magnetic sensors like on the SC. The white wire is for points.
-Andy
Old 09-07-2021, 05:13 PM
-Andy
Good information.
Thanks Andy.
Cheers,
Frank
Old 09-07-2021, 05:16 PM
Racer
winders's Avatar
Thanks, Andy.....yeah the Green and Violet trigger wires are what I was thinking about.
Scott Winders
PCA GT3 #3
Old 09-07-2021, 05:23 PM
