G50911's Avatar
23mm master cylinder question...
i'm looking for a 23mm master and wondering if anyone who's done this can give me a part# or a lead on where to purchase? i heard it's a MBZ product but not sure. looking for the non-booster version. TIA
1967 911 (Azzuro Thetys) - #308439
1971 911 (PTS Black) - Built 3.6 Sleeper
1989 911 (Grand Prix White) - Cabriolet Bone Stock
Old 01-08-2018, 12:41 PM
disband
juanbenae's Avatar
https://www.ecstuning.com/b-trw-parts/brake-master-cylinder/8d0611021b~trw/
confirm with mr verburg, but I think this is the one.
Old 01-08-2018, 01:07 PM
Bill Verburg's Avatar
Depends on the year
for boosted card from '77 up use the 930 m/c
for non boosted use ATE (ports face left) # 03-2123-3402.3
for the latter ATE you also need a longer 105x7mm actuating rod, and 2x 45° plastic fill fittings + usually a few feet of fiber fill hose
These parts used to come in a nice kit
I used to get the kits from JWE, I hear they are still in operation on a limited basis or perhaps give Steve Weiner a buzz
Bill Verburg
Old 01-08-2018, 01:20 PM
The 911 Turbo mc is a 23mm. Buy it here from the host of this website that is providing all the info on 'how to' DIY and access to the hundreds of Porschefiles!
Tony G
2000 Boxster S
Old 01-08-2018, 01:24 PM
Nope, that is only for the 996/Boxter/Cayman up
Bill Verburg
Old 01-08-2018, 01:27 PM
G50911's Avatar
thanks for the replies. this would be for a non-boosted car. i found this online, part# is 03-2123-3402.3 so can i assume it's the correct one? doesn't include the angle plugs but i already have the hose and adjustable pushrod.
lightbulb8817's Avatar
I believe there's a 90 degree elbow off a 993 clutch master cylinder that will also fit and work as the 90 degree elbow for the 23 mm brake m/c. That part number is 911-423-923-00. I haven't tried this yet though so I'm not certain it'll work.
The ATE part number for the 23 mm m/c (non-boosted) appears to be correct based on the fact that it matches the part number I received in a kit I purchased recently (ATE 03.2123-3402.3) - ports facing left for left hand drive cars.
You may also need a 10 mm plug if your existing m/c is like mine which has two brake lines coming off 1 port as seen in the following photo. Ignore the 23 mm m/c i'm holding on up this photo. It was a different 23 mm m/c with ports facing passenger side.
Old 01-08-2018, 02:02 PM
G50911's Avatar
so looks like the one i saw has the manufacturers part number of 002.430.93.01 and/or 537.33006.237 but it's interchangeable with 03.2123-3402.3
comparing it to yours @lightbulb8817 it's a little different configuration. does it appear that way to you also?
Old 01-08-2018, 02:21 PM
Ignore the 23 mm m/c with the blue tape on it in my photo. That's not the correct one and it doesn't match the part number i gave. I returned it to get the correct one.
Old 01-08-2018, 02:33 PM
Here's a 23 and a stock 19, the 19 has the pressure actuated brakelight switch, the 23 needs to have a switch on the brake pedal
Here's a 23 installed, There's more room w/ an alloy cross member than w/ a steel version
Bill Verburg
Old 01-08-2018, 02:36 PM
get it from redogmotorsports.com he is on here somewhere. he has nice kits and all the premade lines
Old 01-08-2018, 03:47 PM
G50911's Avatar
thanks for the additional pics bill. here are some of the one i picked up...
G50911's Avatar
anyone know where i can get a longer actuator rod? or should i just make one myself?
Old 01-11-2018, 06:00 PM
unless you buy the kit you'll need to make one
here's what they look like
Bill Verburg
Old 01-12-2018, 05:52 AM
I was told a push rod from '67-68 will work, but i haven't tried it myself.
Old 01-12-2018, 08:03 AM
G50911's Avatar
thanks for the heads up and thanks bill for the pics. i went to hardware store and only found a grade 10.9 bolt in the size i needed. it's a little overkill but i picked it up anyways. i'm going to attempt to cut and round the end off but i don't have high hopes cause this sucker is hardend.
as a backup, i called pms and they sold me one of their pushrods and 90* elbows so i should be covered!
Old 01-12-2018, 10:36 AM
I have a 23mm MS in my 73 hot rod that I just purchased. It came with 930 front rotors & calipers, but the set up is quite stiff when depressing the brake pedal. Still trying to figure out if the oversized 23mm MS is the reason for this.
1970 914-6 #2615 (Metallic Green) - SOLD
1974 911 US Carrera Coupe #63 (Lime Green)
1973 911 T Coupe #1891 (Gemini Blue)
Old 01-12-2018, 10:39 AM
G50911's Avatar
what's up steve! does your 73 have a brake booster? if so, check that.
Old 01-12-2018, 10:45 AM
It's hard to tell w/o knowing what the rear spec is
Bill Verburg
Old 01-12-2018, 11:31 AM
no brake booster. Rears are stock.
Old 01-12-2018, 02:15 PM
