Shift coupler update?
I recently replaced the bushings on my shift coupler, and then I noticed that both JWest Engineering and Wevo sell upgraded shift couplers. Has anyone tried either of these, and did it make any difference?
82 911SC Targa |
83 SC
I went to WEVO and love it. Took a little work to get it adjusted right because there's less play in the design, but once adjusted it shifts more crisp and smooth; plus no bushings to wear out.
Insert Tag Line HERE.....
Second best upgrade you can do after the Wevo shifter itself..
Before I became aware of the Wevo and the Renshift products, I read about the Porsche short shift kit (our host gives it rave reviews). So I went ahead and installed that upgrade. It was a significant improvement, for sure. I have no idea how much more improvement, if any the Wevo or Renshift shifter would be, than the Porsche unit. Has anyone tried both the Porsche and one of these others?
Another thread also suggests that replacing the clutch cable can improve shifting as well. Since I had a cable snap on me while driving a 914 once, and since I'm still not satisfied with shift performance, it seems like a good idea on a 32 year-old car with 116K miles. So that's next on my list, but looking past that, perhaps the coupler upgrade. Btw, the 915 transmission I'm driving was rebuilt approximately 20K miles ago.
82 911SC Targa |
83 911 Production Cab #10
I upgrade to the PRECISION SHIFT COUPLER (SR010) from STOMSKI RACING.
Very nice, available here (11 item down the page): Porsche 911 (1974-1989) - Shift Linkage - Page 6
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Location: behind the redwood curtain, (humboldt county) california
First, replace worn out stuff...
Shortly after I got Dad's 74 home, the shift shaft bushing grenade, then I found out that the cup bushing was sloppy as well - it really shifted badly, very very sloppy.
I replaced both front bushings and installed the factory short shifter and of course, it was a major improvement. I bought a new factory coupler but haven't installed it yet. I am thinking replacing the stock worn out unit with either a stomsky or Wevo unit, probably the wevo unit. Additionally, I think I will install the wevo shifter, primarily for the spring loading of the 2-3 and secondarily for the shortened shift, (like the factory short shifter). Unfortunately, I think the trans is due for a major overhaul, LSD, budget permitting. So, the short version of all of this is to check the front bushings as well as the rear coupler, then decide how much you want to spend on the shifter:-) chris P.S. looking forward to discussion of the various coupler units. PPS Don't forget to check the engine and trans mounts too. Slop in either or both don't help the shifting experience. I have opted to go with the poly, (sport hardness) tranny and engine mount pieces, not stock rubber or solid. Last edited by chrismorse; 09-04-2015 at 06:11 PM.. Reason: brain fade....... |
The shift from 2nd and 3rd is now unbelievably fast. 12 item down the top of the page: Porsche 911 (1974-1989) - Shift Linkage - Page 5
Has anyone replaced the stock plastic bushings with delrin or metal in the stock coupler for a 901 shifter? Did this make a difference?
1970 Porsche 911 E Coupe/Targa - Shift Linkage - Page 4 |
I have had the Wevo in my 1973 911 for 6 years and love it. Huge difference from stock. I am sure the Stomski and Renn are good as well.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
The Wevo coupler is great. I assume the Stomski is as well, but I don't have first hand experience with it.
However, if price matters and you have the tools., skills, and inclination to change the bushings, I recommend trying a set of the 10-15 dollar circular centered bushings before jumping for one of the u-joint couplers. I started with circular centered bushings, but decided to try a Wevo PSJ anyway. I could detect no additional benefit from the PSJ, and I ended up going back to the enhanced factory coupler.
Joe Frantz 73 911 T |
Can anyone ID this coupler for me? I picked up some bass bushings from our host but its clear to me work is going to be needed to make then fit into this coupler.
It looks to be billet but the machine work looks a little unfinished on the inside....
'77 911S Coupe 3.2 Turbo '76 911S Coupe 3.0 964 cams...no sunroof '75 911S Cabbie 3.2 SS Web cams & 46mm Webers '73 914 1.7 Webers & Header ... sold '74 VW 1303S 1600cc DP Web 110 & Solex Last edited by Das Schnell Ei; 09-05-2015 at 09:07 AM.. |
Brew Master
I've got brass bushings in my coupler and with the short shift and seine gate shift I think it feels as nice as my brothers car with wevo coupler and shifter. Just my .02
Thanks for the input. Just what I was looking for. What is the seine gate shift? Maybe I will just search on that.
Click on the link at post #7
Brew Master
Below is a link. It's really money well spent. I fought buying it for over a year then after looking at other shifters and their cost decided to go this route. The install is really easy but you need a welder to permanently attach the tab to the shift lever. Seine Systems > Gate Shift Kit I'm curious, you mention you're not happy with the shift performance. What problem are you having and have you replaced your transmission mounts or inspect them? I've read that the mounts can make a BIG difference in how the car shifts. Last edited by cabmandone; 09-05-2015 at 10:57 AM.. |
I decided to go with the JWest (Stomski) coupler (in addition to my factory short shift kit). It did improve shift accuracy, but it was not overwhelming. I'm guessing the brass bushings would do the same thing, and cost a bit less (but a lot more work to install). I've also replaced my clutch cable and my omega spring, btw. This also helped a bit. When the car came to me a couple of months ago shift crispness was mediocre. It has improved quite a bit, but I have to believe it can get better. My tranny was rebuilt less than 20K miles ago, but it doesn't have the snap that I would expect. I'm going to change the fluid this weekend, and if that doesn't get me to where I want to be I'll look into replacing the mounts.
82 911SC Targa |
Shortly after purchasing my '86 I installed the Wevo shift kit and coupler. Night-and-Day difference. Anyone could drive the car now w/out having prior 915 knowledge. I had someone even question if I actually had an '86; he thought it was an '87 or newer because it shifted so well.
Worth every penny and I've not looked back since. I think it's the best upgrade I've done. Al |
Looks stock to me.. The coupler needs a little sand paper taken to it to wear down the edges then it needs tapped into place using a quarter and socket extender. I just put those bushings into mine a couple weeks ago. It's a tight fit and shaved some of the housing out when tapping it into place, but they will make it in there!!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C |
Forgot the pic.
Dial 911
Coupler
I have had one of his for 3 years now, and from the day that it was changed, it made such a huge improvement...Amazing actually. He had just started to sell a shifter kit -'Secret Shifter' - that was also an excellent product, but due to his wife's health, (cancer) he then put everything on hold. I do though know that he still has the kit's for the coupler. Many on this board have purchased them and found that they were excellent. If anyone is interested here, is his site: The Secret Shifter - The Coupler Whisperer If anyone wants to make a search on the board there is a good thread on the product. If I remember right, I believe that his name is ED Mitchell?...A super nice guy
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci Last edited by A horse with no name; 09-24-2015 at 06:47 PM.. |
