1983 911SC making intermittent sucking sound at idle
For lack of a better descriptor perhaps, my engine was making a new sound when I started it yesterday. On cold start it had a brief surging idle and quickly smoothed out. As the car was idling, I heard a new sound that was like a sucking or squeeeeshing sound every 10-15 seconds or so and would only last for a few seconds each time. At first I thought it was a belt noise but I don't believe so. Took the car for a 15 minute drive, parked it in front of the garage, did a few things in the garage, went back out to pull it in and would not start, turns over fine but will not fire. Waited overnight to try cold start rather than warm start and same result. If my fuel accumulator was about to fail, would it make noise? It was definitely coming from the engine bay. In hindsight, wish I had taken a video to capture the sound, would have been more helpful than my "descriptors".
Read in one of the threads with similar starting issue that one check is to remove the airbox lid and air filter and with key in power on position, push the silver lever beneath the fuel distributor. I was not able to find that thread again. Wondering how long to hold the lever upwards before cranking over?
Try turning the idle speed air bylass screw a tad in ot out until the noise stops. Probably just an air whistle. The big slot screw with the spring under it on the throttle housing.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 07-07-2022 at 10:00 PM.. |
Thank you John, will give that a try once I get her going again. Despite the odd noise, it did run fine and has for months but failed to start after the last short drive. Need to check fuel pressure, make sure I am getting spark.
ROW '78 911 Targa
Do you have a pop off valve installed in the air box?
If yes, check the o-ring is sealing. Or the unit hasn’t worked itself loose.
Tried something different this morning, left the key in the power position for about a minute then cranked. The car tried to start very briefly. Tried cranking over again and no start. Did again with key in power position and waited, tried to start for a second or two. Fuel pump/pressure? I guess best way to rule in or out is to disconnect the fuel line at top of the fuel accumulator and crank over? Best to let car sit overnight before doing so?
Check pop off first
CIS troubleshooting......
What are you trying to achieve or test? Does the FP run when you turn the ignition switch to ON/RUN position (not START)? There are several things you need test or check to identify the culprit for your no-start problem:
Tony |
hopefully you did not hear any sound of mini bang..-in bad case air box split....
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Got it running. Simply swapped the relay for the ac and fired up on first turn of the key. Will order new FP relay. Feeling pretty dumb now but if it ever happens on the road, I will know what to do.
Congrats!
The red relays contain a suppressor diode, the black ones not. You have to use the red relays for the fuel pump, you *can* use them as well on other circuits as the black ones, but not vice versa. https://forums.pelicanparts.com/porsche-911-technical-forum/305738-930-fuel-pump-relays-red-black.html Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
https://components101.com/articles/how-to-use-tvs-diodes-for-transient-voltage-suppression Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 07-17-2022 at 08:23 AM.. |
