-   -   check, measure adjust question (http://forums.pelicanparts.com/porsche-911-technical-forum/110217-check-measure-adjust-question.html)
Tim Walsh 05-10-2003 07:06 PM
I was reading through the check measure adjust manual and there is a note in it about if you run a 72 or 73 engine on gas that is "98 octane" then you will have a high CO content. I currently run premium(93) in my 73T. When I go to do check measure adjust will this throw off the readings?
Tyson Schmidt 05-10-2003 07:45 PM
Yes it will. The ultra-low compression of your engine makes premium fuel unnecessary. Like it states, higher octane fuel is harder to ignite in a low compression engine. Your car will actually run better on regular.
Jim Richards 05-10-2003 08:15 PM
Tim, we run only regular in Lu's 73E. Like Tyson says, premium fuel is unnecessary...even after you upgrade your 73T to 2.7RS specs. ;) :D
Tim Walsh 05-11-2003 05:25 AM
hehe but what about a 2.7 RS with a 9.8:1 C/R :D
Thanks for the reply guys!
