Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
check, measure adjust question
I was reading through the check measure adjust manual and there is a note in it about if you run a 72 or 73 engine on gas that is "98 octane" then you will have a high CO content. I currently run premium(93) in my 73T. When I go to do check measure adjust will this throw off the readings?
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 05-10-2003, 07:06 PM
PRO Motorsports
Tyson Schmidt's Avatar
Yes it will. The ultra-low compression of your engine makes premium fuel unnecessary. Like it states, higher octane fuel is harder to ignite in a low compression engine. Your car will actually run better on regular.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 05-10-2003, 07:45 PM
Bandwidth AbUser
Jim Richards's Avatar
Tim, we run only regular in Lu's 73E. Like Tyson says, premium fuel is unnecessary...even after you upgrade your 73T to 2.7RS specs.
Jim R.
Old 05-10-2003, 08:15 PM
Tim Walsh's Avatar
hehe but what about a 2.7 RS with a 9.8:1 C/R
Thanks for the reply guys!
Tim
1973 911T
2005 VW GTI
Old 05-11-2003, 05:25 AM
