-   -   Access to Shifter (http://forums.pelicanparts.com/porsche-911-technical-forum/1102256-access-shifter.html)
nomata 09-14-2021 11:45 AM
Access to Shifter
Shifter is a little sloppy and the linkage seems loose. I need to adjust it but I need to know the best way to access the 3rd screw that holds the console in place directly in front of the e brake. Do I need to cut thru the carpet or is there another way?
911pcars 09-14-2021 12:18 PM
This short description might help:
Remove Console
Sherwood
Tommy Z 09-14-2021 12:30 PM
Just carefully pull it back from the top and tuck the carpet back under when you install the console again. Easy peasy.
nomata 09-15-2021 07:57 AM
Remove Console
Sherwood
Thanks for the step-by-step procedure. Very helpful.
