Access to Shifter
Shifter is a little sloppy and the linkage seems loose. I need to adjust it but I need to know the best way to access the 3rd screw that holds the console in place directly in front of the e brake. Do I need to cut thru the carpet or is there another way?
Old 09-14-2021, 11:45 AM
This short description might help:
Remove Console
Sherwood
Old 09-14-2021, 12:18 PM
1979 911 SC
Just carefully pull it back from the top and tuck the carpet back under when you install the console again. Easy peasy.
Old 09-14-2021, 12:30 PM
Remove Console
Sherwood
Thanks for the step-by-step procedure. Very helpful.
Old 09-15-2021, 07:57 AM
