Oil Level
Is there a lot of oil in the lower valve cover after the car has sat overnight? So, can you check valve lash w/o draining oil?
Why do you need to check lash? You may be able to do this by jacking up one side of the car to have it drain into the sump. I have done this after an adjustment and had one ticking valve.
For same reason
Robert Williams 70' 911T |
i do not really see a big deal to drain the engine oil to a clean bucket..usually 3 Q of oil..then do the valve adjustment s and put it back ....Just put the car on jack stand and be safe..this way the 911 is balanced ..oh ya replace the drain plus alu.seal while you are at it.
Ivan
1985 911 with original 501 587 miles...807 226 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I pull my valve covers with oil in it. just have to keep a pan under it.
not much comes out, maybe a cup. but I also try to let the oil level get down a little.
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
i suggest to never pour back any drained oil. Any impurities will not be caught by the oil filter
80SC (ex California) |
