freesaints's Avatar
Modern blade fuse comparisons
Looking at upgrading the fuse panel with a modern blade system. I have an '87 930. I know Classic Retrofit is pretty active here on Pelican but does anyone have any comparisons between the Classic Retrofit panel and CDD Autogear and Adapt Motorsports panels? In order of pricing, from high to low, it looks like it's Classic Retrofit, CDD and then Adapt Motorsports. My question is on quality.
1987 Porsche 930 - Grand Prix white
1998 Acura NSX - Kaiser silver
1976 Jeep CJ5 - Sunshine yellow
Old 04-21-2020, 11:06 AM
CDD Autogear is high quality. Its also made in the US. I have no experience with the other options.
1966 912 to 2.7 Frankencar
Old 04-21-2020, 02:50 PM
I used the Classic Retro panels on my 930. It worked well.
Old 04-22-2020, 08:26 AM
freesaints's Avatar
Thanks for the feedback guys. If anyone else has used any of them, interested in hearing about your experience on the install as well as how they've held up over time.
Old 04-22-2020, 08:55 AM
I run CRF on my cars. I like their LED's and one of them has been in for multiple years......works great.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 04-22-2020, 09:09 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
I used the CCD, painless and owner is super responsive. Would do over in a second for the next car. The quality of the CCD panels are aircraft/OEM quality far superior to the stuff it replaced. Dont forget to source a selection of wire thimbles to replace the ones missing or clapped out. My wires that were corroded were trimmed and stripped to proper length prior to replacement.
Classic for my upgraded alternator:
https://www.classicretrofit.com/collections/upgraded-alternators/products/porsche-911-high-output-150a-alternator
Lighter, modern alternator, driven by Clewett upgraded pulley and belt system.
My car lives outside in a covered carport, if my car sat for a few days, the original ceramic fuses would corrode and cause electrical weirdness. I carried a red scotchbrite pad in my tool kit to burnish the fuses and contacts. After the CCD my car can sit for weeks(covid19) and fire right up with none of the grief from the fuse panel.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 04-22-2020, 09:20 AM
Perpetual Reassembler
2jmotorsports's Avatar
Here's my experience installing the Adapt Motorsport unit:
https://www.youtube.com/watch?v=BpLYsd7sAQs
I havent had much seat time with it installed but so far no issues. I may pop in and update as my mileage increases. Seems like a solid unit.
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 04-24-2020, 04:24 PM
In the market now and was looking at the Classic Retrofit panel here, but the website is down and I wonder what's up: www.classicretrofit.com. I wanted to ask if the on-board relays are electronic or mechanical.
The CCD ReFuze looks solid. but I like the LED, on-board relay, and the mini blade fuses of the Adapt Motorsport unit. Do you know if the Adapt uses electronic or mechanical relays?
Chris
911 Carrera Sport Coupe (1989)
996 GT3 Cup Car
981 Cayman GT4
Old 09-30-2021, 06:44 AM
