ODO/trip doesn't work after repair question
Question for the knowledgeable folks on here. Recently had the ODO stop working on a 1982 911. Speedo works but not the trip/ODO. Assumed the two broken plastic gears (as Ive seen before on another car). Pulled the speedo and sent to a local shop. Tech confirmed broken gears, showed them to me after replacement, and bench tested in front of me where both trip and ODO worked.
I brought the newly repaired unit home and reinstalled. Speedo works but still no trip or ODO. everything "seems" to be in place- all connections and sender.
Has anyone had this happen before or have any thoughts on what could be the problem?
thank you all in advance for your time.
Regards,
MADC
Old 09-18-2021, 05:09 PM
Any help or thoughts would be truly appreciated.
MADC
Old 09-27-2021, 03:30 PM
Checked out
McLovin's Avatar
If the speedo is working, the problem has to be internal in the gears.
Old 09-27-2021, 03:40 PM
I had the ODO fixed at PA Speedo and plugged it in and it worked. Ask the shop.
Sold: 1989 3.2 coupe, 112k miles
Old 09-27-2021, 04:00 PM
That is the problem for the speedo shop, not you.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-27-2021, 04:36 PM
Brew Master
cabmandone's Avatar
Double check your connections. My ground wire cluster was loose on mine and it caused the odo/trip not to advance. I had to pinch the female connector tighter to make better contact and it started working again.
Nick
Old 09-27-2021, 04:47 PM
As mentioned above... if the speedo works and the odo doesn't then it's either the plastic gears or the stepper motor. I've seen a couple lately with intermittent stepper motors. It seems like they develop bad spots. If the gears are new and it worked after they were replaced then my guess is the stepper motor.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 09-27-2021, 08:14 PM
Thank you all for the replies. I will check all connections and retrace my steps. If that doesn't work, back to the speedo shop.
Thank you again,
MADC
Old 09-28-2021, 10:06 AM
