Circlip size
67 911 IMS chain gear retaining circlip.
NLA PorscheG90004102500 Does anyone know the dimensions. The later ones 68 onwards are available so I'm presuming are a different size. Thanks lyndon |
I don’t have a size but the intermediate shaft on early aluminum cases runs directly against the case surface without separate bearing.
The shaft bearing surfaces and shaft are considerably larger than the later years Bruce |
It's the same as the later ones.
36x1.75 All done Lyndon |
