-   -   Media blast for RSR look on fuchs??? (http://forums.pelicanparts.com/porsche-911-technical-forum/1103423-media-blast-rsr-look-fuchs.html)
2.7RS 10-01-2021 07:30 AM
I have a set of fuchs that I want to refinish on RSR look.
Anyone know what grit of glass bead to use in the barrels?
I want that nice aluminum frost.
Youtube didn't help.... Not very detailed
After Im done I'll paint the petals black.
73pcar 10-01-2021 09:01 AM
I can't help with the grit size of glass bead, but you might first try plastic media (recycled plastic). I used it recently on some FUCHs caps, and it worked perfectly...very easy to control the desired finish.
DucRS 10-04-2021 02:49 PM
I too am considering this exact RSR finish. If this doesn’t work, I’ll send them off for a proper RSR finish.
Harpo 10-04-2021 04:30 PM
I submerged my rims in water until I got to the desired depth then used Eastwood 2K rattle can epoxy paint to add the silver for the pedals and lip. The water masked off the black recess.
Showdown 10-04-2021 04:42 PM
I had mine glass bead blasted (glass bead mixed with water) and the finish was seductively satin. So beautiful. Unfortunately it was such a fine tooth that it was almost impossible to get dirt and oils out of it. In addition I would have had to anodize them to protect them so I opted to paint the rims with silver and satin black. I can wash them off and they look perfect.
Jeff Alton 10-04-2021 09:46 PM
#6 glass bead, Then clear anodized.
Cheers
