Behind the Sun
Media blast for RSR look on fuchs???
I have a set of fuchs that I want to refinish on RSR look.
Anyone know what grit of glass bead to use in the barrels? I want that nice aluminum frost. Youtube didn't help.... Not very detailed After Im done I'll paint the petals black. |
I can't help with the grit size of glass bead, but you might first try plastic media (recycled plastic). I used it recently on some FUCHs caps, and it worked perfectly...very easy to control the desired finish.
I too am considering this exact RSR finish. If this doesn’t work, I’ll send them off for a proper RSR finish.
I submerged my rims in water until I got to the desired depth then used Eastwood 2K rattle can epoxy paint to add the silver for the pedals and lip. The water masked off the black recess.
Full Send Society
I had mine glass bead blasted (glass bead mixed with water) and the finish was seductively satin. So beautiful. Unfortunately it was such a fine tooth that it was almost impossible to get dirt and oils out of it. In addition I would have had to anodize them to protect them so I opted to paint the rims with silver and satin black. I can wash them off and they look perfect.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
#6 glass bead, Then clear anodized.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
