Question Durant mirror glass replacement -- anyone use convex?
Replacing my desilvered Durant driver's mirror -- anyone use convex glass on the driver's side to improve the vision? The view from the 5" Durant with flat glass is almost useless.
Good idea, or would be annoying to have a fisheye primary rearview?
Old 10-03-2021, 07:50 AM
digitaldgp's Avatar
I installed a convex in my 1970 911, way better than stock 5 inch.
1970 911T "Albert"
1986 944 Sold
1980 Euro 924 Sold
1967 911 Sold but Greatly Missed!!
Old 10-03-2021, 02:19 PM
digitaldgp's Avatar
https://www.flickr.com/photos/10448935@N04/51547979090/in/datetaken-public
1970 911T "Albert"
1986 944 Sold
1980 Euro 924 Sold
Old 10-03-2021, 02:20 PM
Terrific. Thanks for the advice. Leaning that way myself.
Old 10-03-2021, 04:38 PM
where are you guys sourcing replacement glass? I called a bunch of places near me (sf bay area) and none were interested in cutting only a single piece.
Old 10-03-2021, 07:02 PM
Got some different ones off amazon that fit, with some modifications. Glass from 5" auto mirrors are pretty close. Have not finalized the fit yet though.
Old 10-04-2021, 06:44 AM
digitaldgp's Avatar
Velvac 708520 Stainless Steel 5" Center Mount Convex Mirror
I used this and just removed the mirror, have to be careful, I broke the first one on attempt.
It is glued in with 2 globs of RTV silicone.
1970 911T "Albert"
1986 944 Sold
1980 Euro 924 Sold
Old 10-04-2021, 08:29 AM
Back in business. I used this convex one:
https://www.amazon.com/dp/B00029WSZE
The whole job was fairly delicate to pull off TBH, including reducing the diameter odf the mirror about 1mm all around to fit properly in the black bezel.
I do not want to go back in there and do that again anytime soon. On the plus side, the mirror is now adjustable again.
@Lz7w let me know if you want to see it in person sometime.
Old 10-04-2021, 03:52 PM
There may be trick to easily remove the plastic retaining ring to access the Durant glass. I found it difficult. The ring was easier to remove if the glass was already damaged.
One option is to install a small 2" convex mirrors on top of the existing mirror. That should provide an increased viewing angle to spot approaching vehicles while also having a more correct perspective of vehicle proximity.
https://www.amazon.com/LivTee-Mirror-Frameless-Convex-Adjustable/dp/B07ZFHF14Q/ref=sr_1_20?dchild=1&keywords=small+convex+outside+mirror+add-on&qid=1633392374&s=automotive&sr=1-20
Sherwood
Old 10-04-2021, 05:16 PM
thanks for the input folks. @torch, I’ll message you about taking a look.
Old 10-05-2021, 09:37 AM
Quick update:
The mirror went from useless to very useful. The slight fishey on the convex takes a little mental adjustment, but the visibility is about 4X better.
Old 10-06-2021, 07:06 AM
Advice
Any tips on removing the black retaining ring from the metal frame?
Old 05-05-2023, 01:54 PM
I think breaking out the old glass first was key for me getting the black ring out. Then you can get a grip on the far side of the black ring without marring the steel or plastic. I may have heated it a bit in hit water or heat gun. It was definitely tricky to get out as I recall.
Old 05-07-2023, 06:50 AM
