1972 911T with MFI
HELP. I have a 1972 911T Targa with MFI. The engine was rebuilt by the previous owner, has about 3,000 miles on it, an runs fine. The Problem? This thing sucks the gas, about 10 mpg around town and I drive it gently. Gets about 15 mpg on the highway.
When I first got this car, there was a very noticeable flat spot while accelerating at about 3000 to 3500RPM. To alleviate, I made a slight adjustment in the part load mixture by making it a little richer. The has helped alot. The flat spot is still there but it is signicantly better, hardly noticeable, since the adjustment. Is this the problem with the gas mileage?
I had a 1973 with the CIS engine and it spoiled me for good gas mileage.
Any suggestions for other adjustments?
Thanks for any help you can provide.
Doug
Old 05-08-2003, 08:21 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
does your microswitch work?
On the left side of the engine there is a switch that is pushed by the throttle linkage. If that is bad or is maladjusted it will also drop your millage alot since when you're coasting it will still dump gas into the engine.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 05-08-2003, 08:26 AM
Tim,
Hmmm, interesting question. I will check it out.
Thanks very much
Doug
Old 05-08-2003, 08:44 AM
boyo's Avatar
Easy way to check - with the engine off open the hood and see if the microswitch is engaged. If it isn't, it's been disabled. Likely the culprit are the crumbling electronics in the small module in the left hand side of the engine bay.
Search "microswitch" on this board to find replacement options - have fun!
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '72 Porsche 911T
Old 05-08-2003, 09:52 AM
Thanks for your response. Yours is the second reply suggesting a problem with the microswitch. Will check it out. This engine was rebuilt by a backyard mechanic who could have easily neglected this switch in terms of adjusting, etc.
Doug
Old 05-08-2003, 10:16 AM
Halm's Avatar
Doug, Get your hands on a Gunson Gas Analyser and check the readings. There is an excellent article on this in the Tech section. My mileage was about 16 highway and after an adjustment it went to well over 20mph. We leaned it down 14 clicks and drivability improved dramatically as well.
As for the Microswitch, I doubt it is the cause of low gas mileage. Backfires on over run, yes, but not gas mileage.
'17 Cayenne
Old 05-08-2003, 10:24 AM
same car and i get about the same mpg with a working overrun circuit.
best $20 to go 100 miles i ever spent.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 05-08-2003, 10:25 AM
tobluforu's Avatar
Get use to it, these cars love to run rich which in turn sucks the gas
Old 05-08-2003, 10:39 AM
pwd72s's Avatar
As far as the flat spot goes...are you running an aftermarket exhaust? That alone could do it. See? Another search for you...
Old 05-08-2003, 11:24 AM
No, running a stock exhaust.
Doug
Old 05-08-2003, 11:26 AM
Autodidactic user
David E. Clark's Avatar
Before I spent a lot of time or money, I'd make sure the easy, lo-cost things are OK. Are the tires properly inflated? Are the plugs clean and properly gapped? Do you need to replace or clean the air filter? Is the timing correct? When was the last time you cleaned the MFI thermostat This contributes greatly to a rich running condition. There are many good threads on this; search "Clean MFI Thermostat." Also make sure the hot air hose from the left heat exchanger to the thermostat is connected and not kinked or damaged in any way. Without this hot air, the thermostat will take a very long time to lean out. Overly rich = poor fuel economy. It might pay to check the easy things before you get into a big project. Good Luck.
'73 911E
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 05-08-2003, 11:33 AM
Warren Hall Student
Bobboloo's Avatar
Go to http://www.pelicanparts.com/techarticles/911_MFI/TipMFI.htm
Download Check, Measure, Adjust. This is required reading before touching anything in your MFI system.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 05-08-2003, 11:38 AM
Seldom Seen Member
Burnin' oil's Avatar
10 mpg in town? Not bad, not bad at all. I wish my '73 did as well . . .
Why do things that happen to white trash always happen to me?
Got nachos?
Old 05-08-2003, 12:43 PM
Burnin'Oil
You should see some of my responses. Most everyone thinks the car should do better. Perhaps you should pursue the problem for your car.
Doug
Old 05-08-2003, 12:46 PM
Autodidactic user
I second the check, measure, adjust recommendation. You can find a better (more legible) copy here:
http://www.scatliff.mb.ca/pelican/MFI_Check_Measure_Adjust.pdf
Thanks to poster Derek Murray
Old 05-08-2003, 12:50 PM
Seldom Seen Member
I believe that my fuel consumption is primarily related to Webers and uncontrollable and frequent spasms of my right leg and foot.
Got nachos?
Old 05-08-2003, 12:51 PM
PRO Motorsports
Tyson Schmidt's Avatar
My '72 T, which I obsessively tuned and adjusted, would get 15 city and as high as 29 highway.
One of the things I found while "obsessing" over my MFI was that the space-cam wore a groove in itsself that made adjustment a moot point. The '71 and earlier pumps had a narrower cam with a roller follower that didn't seem to have this problem. With the '72 and later cars, the follower was more of a ball point device. That, coupled with some surface hardening of the space-cam (or lack thereof) issues caused the wear grooves.
My point is that you may have to break down and just send the pump to Pacific Fuel Injection for a rebuild. Of course, follow all the steps in the Check, Measure and Adjust manual first.
Good luck!
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 05-08-2003, 08:14 PM
Tyson, thanks for your reply. Just of of curiosity, what does it cost to have those pumps rebuilt. I have heard it is spendy but have no specifics.
Thanks, Doug
Old 05-12-2003, 09:20 AM
Tim Walsh's Avatar
I've heard you can get them rebuild for anything from $450 to over $1200. Pacific fuel injection might be right in your area even. Give Gus a call there and he'll let you know how much.
Tim
1973 911T
2005 VW GTI
Old 05-12-2003, 09:23 AM
I've spoken to gus before a/b a pump bench test and rebuild. he said it would be over a month until he could test my spare kugelfischer pump. and I'ver heard that a rebuild can take 6 months.
maybe he get's to the porsche MFI pumps quicker... but at over $1k for a rebuild... I found another source. I ended up using a guy in redding, ca who had a 1 week turnaround and price of $350 for the rebuild.
but from what I understand Gus is THE BEST... he just didn't work for our time frame and budget.
paul schuster
Old 05-12-2003, 11:02 AM
