DME relay location
I'm new to the Porsche world. I am working on a 85 911 turbo. I am experiancing a crank no start condition. The fuel pump does not turn on. Everything i am seeing on line points to a possible DME relay falure. I can"t seem to locate to relay. This is a gray market car so I'm wondering if anyone could tell me if it has a DME relay to begin with a where it is located if it does.
FP relays (2) are on the front fuse board. Usually red, rearmost positions. FP fuse is #6. There's also an overboost relay on the rear electric panel, yellow, that keeps the pumps from running wnen the overboost switch goes open circuit from too much boost, bad switch or the wire fell off. That relay can suffer cracked solder joints also.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 05-24-2016 at 09:28 AM.. |
The DME relay on a 3.2 is under the driver's seat.
Slide seat to front and back to access the bolt and harness clip.
1986 Bosch Icon Wipers coupe. |
it's a 930. No DME.
installing DME relay
Best to Unscrew the bolt that holds down the tab --
