Black and Blue
Targa doors vs coupe doors...are they compatible?
helping a friend with a project and need a couple of doors as he is going back to street with his track car. if the window frames are good on his track car, will the doors from a targa work with a coupe and just swap over the window frames?
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Black and Blue
https://forums.pelicanparts.com/porsche-911-technical-forum/1036731-86-targa-driver-door-86-coupe-possible.html
search is my friend and i value John Walker's input
Yes, the difference is the window frames which bolt on.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Depending on year there is a small “closing piece” , easy enough to get rid of to fit the rear frame piece though ….
so if i wanted to go the opposite way and convert targa door window frames to frames from a coupe for improved "seal" it should be doable? (assume targa doors have the necessary frame mount points?
