Harpo's Avatar
Limited slip differential rebuilt tools
Does anyone know the bolt circle dimensions of the transmission output flange? I want to measure the preload on my limited slip differential
Old 09-19-2021, 05:31 AM
Harpo's Avatar
BTW I have a six bolt m8 flange with an od of 101mm
Old 09-19-2021, 05:32 AM
Harpo's Avatar
Old 09-19-2021, 05:45 AM
Harpo's Avatar
Based on the dimensions from the flange this is what I came up with
Old 09-19-2021, 06:59 AM
gearhead
To answer your question, depending on the year and model 100mm or 108mm.
Old 09-19-2021, 08:39 AM
Harpo's Avatar
100 mm please
Old 09-19-2021, 10:28 AM
The easiest way is weld a socket on a bar, then u can do any of them, 914, small 911, big 911. No bold pattern necessary.
Old 09-19-2021, 12:39 PM
Here is one from the service manual, local manufacturer. They just run a nut and bolt thru the hole in the middle.
Old 09-19-2021, 12:57 PM
Harpo's Avatar
It works
Old 09-23-2021, 10:09 AM
How did you cut the square hole in the center?
Thanks,
Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her!
Old 09-23-2021, 10:14 AM
Harpo's Avatar
I had 3 of them cut out on a water jet
Old 09-23-2021, 10:45 AM
Nice job!
Rahl
Old 09-23-2021, 12:44 PM
Harpo's Avatar
Anyone have an extra pair of the elastic bolts to sell?
Old 09-23-2021, 02:00 PM
what is the breakaway torque supposed to be? my wheel turns pretty easily by hand with one wheel up and in neutral. I couldnt find anything about it in the books. It seems to work fine when in use. Other limited slips iv worked on were over 100 up to 200
Old 09-23-2021, 02:41 PM
Harpo's Avatar
According to this guy it is 29 - 58 Ftlbs
https://www.youtube.com/watch?v=yZqvoL0Xaj0
Old 09-23-2021, 03:30 PM
Thanks thats a relief. I was thinking maybe i could test it with a torque wrench on the hub nut but when i gave it a turn by hand I didnt bother
Old 09-23-2021, 04:20 PM
kevingross's Avatar
For which transmission and LSD? FWIW, the factory manuals have a few errors in the measurement they list for a given technique.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 09-29-2021, 01:01 PM
1982 911sc it has the code on it for lsd so its factory
Old 09-29-2021, 03:01 PM
kevingross's Avatar
For a two-disc LSD original to that car, I would look for 10 to 35 Nm measured with both sides active, that is, with one end in an output flange clamped to a vice, the other with your wand-style torque wrench measuring turning torque.
By "two disc," I mean a "40%" LSD with one clutch disc on either side of the pack.
Kevin
Old 10-02-2021, 11:30 AM
perfect. Great info thank you
Old 10-02-2021, 06:58 PM
