Gearing calculation
I have a question regarding gearing
- how to calculate the percentage difference in gearing be between these tire setups. 205/55-16 + 225/50-16 VS 205/50-15 + 225/50-15 |
Thank you winders :) Can you explain what "Aspect Ratio" in the spread sheet is? Sent from my iPhone using Tapatalk |
Aspect ratio is the middle number in the description of the tire, i.e., "P345/25/19" The aspect ratio is "25" representing height over width. The higher the number, the taller the tire (or less sidewall, if you look at it that way). The tire manufacturer usually lists data on every tire they produce. Rollout or circumference will work, as will tire diameter, too. You need to know the actual tire circumference.
Great, thanks a lot :) Sent from my iPhone using Tapatalk |
Thanks a lot :) Sent from my iPhone using Tapatalk |
Tire Rack may have the revs per mile for each tire. Easy to calculate all after that.
speed in mi/hr = (rp_minute*60/(rp_mile * the overall gearing)) overall gearing = cwp ratio * specific gear ratio if you are only interested in the gearing but not the speed then imple division is all that is necessary for say A052; 225/50 x16 OD is 23.9" and rpm is 869 giving an effective loaded diameter of 23.2" 225/50 x16 OD is 25.0" and rpm is 831 giving an effective loaded diameter of 24.3" 23.9/25 = .956 according to this the tire gear ratio is reduced by ~4.4% w/ the taller tire 869/831 = 1.04573 this gives a truer picture the gear ratio is reduced by ~4.6% w/ the taller tire |
| All times are GMT -8. The time now is 09:45 PM. |
