markmalin's Avatar
ICV Availability?
I just checked our host, and some other sites for an ICV for my 85 Carrera. 930-606-161-00. Unavailable. Just curious, does anyone know if there is a cross-reference part, or other sources? They seem to be priced like real estate, as the saying goes...and now maybe not readily available? (Incidentally, I've dismantled and cleaned mine and not much has changed. It works. Just not well, is my guess)
Mark
Mark - New Glarus, WI
Old 10-18-2021, 01:05 PM
Do you get an open/closed response on your ohmmeter from your closed throttle micro-switch?
That has to function in order to bring the ICV into play.
206 637 4071
Old 10-18-2021, 01:26 PM
markmalin's Avatar
I'll have to check again this weekend... I'm fairly certain I did - I went through this all last year before swapping out the 02 sensor.
Old 10-18-2021, 01:27 PM
Flat Six
Flat Six's Avatar
Mark, you can usually find replacements on Amazon or evilBay. This image is from an Amazon listing (this supplier is out of stock, but was selling ~$32 before) that shows cross-application to other makes/models. Might be worth searching your favorite parts sources using these other fitments. GL
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 10-18-2021, 03:46 PM
markmalin's Avatar
I've seen these before, like for certain Volvo's. I guess Bosch is going to re-use the same device for multiple applications. I'll have to look more into this, thanks.
Old 10-18-2021, 03:52 PM
Flat Six
Flat Six's Avatar
NP
BTW, I'm using one right now on my '85; works perfectly.
Dale
Old 10-18-2021, 04:27 PM
Send a message via Skype™ to kyngfish
Went on a mission looking for alternatives to the $300 Porsche part and can confirm the same Bosch part number was used in certain model Volvos. This was years ago and ended up getting it for 50. But this is a dead simple machine and I would put one of those knock off ebay ones in my car so fast today…there are things worth spending on, this ain’t one of them.
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250
Old 10-19-2021, 01:03 AM
You may also want to try this link from Germany. A little more pricey with customs and shipping, but seems like a reputable source.
Old 10-19-2021, 02:50 AM
markmalin's Avatar
NP
Thanks! This is really good to know!
Old 10-19-2021, 05:22 AM
markmalin's Avatar
Thanks. Yah, it is a super simple machine - I completely dismantled mine last year.
Old 10-19-2021, 05:23 AM
brshap's Avatar
I have one of these in my car after searching high and low in vain for a Bosch unit. So far so good.
1984 Carrera 3.2 Targa
Old 10-19-2021, 07:07 AM
I used a 58$ one on my 85, still had to do the procedure of setting idle and CO after making sure there were no vacuum leaks.
Old 10-19-2021, 09:37 AM
