Epic Road Solo Trip #2
Seattle to San Diego and back - 2,800 miles.
She ran like a champ*. I am using about a quart of oil every 300 miles, which seems like a lot. It could be leaking, but there's not that much on my garage floor. The power curve is interesting, there seems to be a narrow band of killer pull, but if I plan my shifts right, I can mostly live in it. When it's there, it purrs and snarls. The only mechanical issue I had was that the driver's side window got stuck down. i worked on it a bit, but I'm going to have to get deep in the door to find the broken part. I got lucky with the weather. Took I-5 down (or "the 5" as the Californians say), but stuck to the beautiful coast on the way back. Big Sur in the dark ... and I mean DARK ... was exciting. Zero deer hit, 100% of corners owned. I think that's probably it for us for the year. Time to start wrenching and keeping our drives shorter and localer.
300 miles per quart is indeed a lot -- I'd pull your plugs and see if any are oil-fouled, as that might give you a clue. Nice car!
That is a lot of oil. Seriously hows the bottom of the engine look? That much oil would have me thinking and oil is either actively leaking or you have a real seal issue which would be showing up on your plugs and in the exhaust.
What an awesome trip - that sounds fantastic! Glad it was mostly trouble free.
Pete, Park City, Utah, USA - Experience level: Low but eager to learn ![]() - 1986 911 Carrera 3.2 Targa - 2018 Factory Five Mark IV 5.0L Coyote |
I’ve done Big Sur at night. Not for the feint of heart.
Brian Miller - Scottsdale, AZ 1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S |
Thanks for the validation on the oil consumption. Seemed high to me too.
Brando
If you were actively leaking you would know it by the amount of oil on your decklid. You’re most likely burning oil.
But that sounds like a blast! The drive down PCH really is nice.
Turbo powa! 1977 911s. it's cool |
Oil consumption of that level means burning - check around your exhaust for tell tale stains. Easy to suck past the valve guides on decel and burn on accel. You ull hardly ever see the smoke thanks to the low exhaust exit and general aero shape of the car.
Nice trip. I have driven out to California three times. The coast road is some beautiful areas to visit.
300 mile per quart is simple excessive. at that rate, you really need to do a top end at the very least. With valve guides and or rings that worn you are near the point of a major and very expensive failure. Valves can break and cause engine destruction.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Thanks for the confirmation on oil consumption, guys. I'm building a winter work list.
What can happen if guides get too worn?
1975 911S Targa Silver Anniversary Edition |
white smoke in the morning or cold engine..
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
troika..i did the similar trip as you but to Napa..only..Too bad you did not drive down south on the 1 at day time ,it is spectacular ...overall i`d bet nice feeling on the round trip;-)
Ivan
So many questions! Please add more details about your lovely car! You’re a courageous maniac driving some of those roads at night. I struggle tooling around suburban Ohio at night. Great shot of your car! BUT you are in the roadway right? I live vicariously through your adventurous heart. Keep driving!!
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
Sounds like a fabulous trip!
How was your trip down I5? I have a '75 Targa - it just doesn't seem to find the right ruts to ride in on I5 around here... |
somewhere midway on the 5 be careful there could sandstorms and it works like a sandpaper on your paint.I had a guy coming once for Sacramento and his whole front was kinda kaput.
Also be aware of the cow fields long drive through very smelly area;-)))) Ivan
The car is a 1976 911S. I am the 3rd owner. The first owner was very meticulous dentist and the 2nd was my dad. I went with him to pick it up and this guy's garage looked like an operating room. My dad loved it and took similar trips in it (apple not far from the tree). He had it repainted the original color code, but he left the engine trouble to me. The 2.7 was end of life when I got it and I sort of fell into a known, reliable, but not yet rebuild 3.0 out of a '79 SC, which is what is still in there today. I have been working on the interior and moved the ride height to the theoretical Euro spec and backdated the exhaust with SSIs. I know that it will need a full or partial engine rebuild and I'm studying those options and decisions now. If anyone has a strong Seattle area recommendation for that process, I will welcome them. I'd love to do it myself, but this is a special car to me and I'd like that job in the hands of a pro. I do want to pull a bit more performance out of it when that day comes. It may not be time, but the oil consumption is worth understanding and addressing. I buried the punchline on the drive through Big Sur at night. The headlights have been acting weird for a while (go out when I signal a turn) and before my KC trip in August they wouldn't work at all. I spend a couple of days reading here and trying to rebuild that switch, but couldn't get it working. I ended up clamping all of those points together and then taking the high-beam fuse out so that they wouldn't be on all of the time. Solved my lowbeam problems, but no high beams! I have a new switch and tried to replace it before the CA trip, but I gave up on connecting the wires at the light switch because there is a metal shield which made it virtually impossible to work under there. I have a window gear issue on the driver's side and my radio went out and I've got this. I think that I'm going to pull the driver's seat and a lot of the interior out over the winter and will try again with less stuff in the way. Last edited by troika; 10-22-2021 at 01:41 PM.. |
