SC Steering Column Clam Shell Covers Bodge/Fix
Hello Friends,
The steering column clamshell covers on my 82 SC were the worse for wear, the little nubs for screws to pass thru (parallel to the column itself) were broken. The two side screws, even with bigger washers, could only exert so much force and in recent weeks, the lower cover fell off. Today I was driving and looking at it sitting on the passenger seat, a symbol of creeping entropy.
My car is very much a driver, so just now I perpetrated something of a bodge, using our faithful friends, the Zip Ties. The two hard plastic moldings are pretty much toast anyhow, so I drilled four 1/8" holes in each and used the zip ties to stitch them together.
I cut the ties as flush as possible, but with the swept back stalk switches and my extended hub wheel, I shouldn't suffer any cut fingertips.
And I won't enter any car shows, but looking at my photos, I'd better go make the way these are oriented to match, side to side.
John
82 911SC coupe
Old 08-28-2020, 04:45 PM
scotricker's Avatar
a Manly Man fix ! Good Job !
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 08-29-2020, 07:31 AM
Vintage Owner
Jack Stands's Avatar
Either zip ties or black duct tape! Sometimes you have to improvise.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 08-29-2020, 07:59 AM
Thanks gentlemen. Sometimes we don't need to be too precious or exacting, but that said, hopefully I don't stoop to that black duct tape though ... that would be a bit much, even for me!
John
82 911SC coupe
Old 08-29-2020, 10:09 AM
1988 Carrera
shadowjack1's Avatar
What a great idea/fix
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 08-29-2020, 02:32 PM
Discseven's Avatar
Nice one John
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 10-22-2021, 10:42 AM
scumbag
I used to do this with mkII and mkIII VWs. It's a great fix for a frustrating problem.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
AchtungKraft #009 - IG: @doktor_b
Old 10-22-2021, 12:00 PM
I was like, “that’s my thread!”.
I love zip ties and see opportunities everywhere to deploy them. My younger kid’s old Accord’s front bumper and grille is held together with them and hot glue.
That said, I’ve since replaced those covers with new repro’s from URO. They are perfect, really nice. But I’ve saved those old ones … one doesn’t toss out old P-car parts!
Best, John
Old 10-22-2021, 04:36 PM
MichaelSJackson's Avatar
If you look around you'll find zip-ties that lay flat; instead of the common ones that stick out at 90 degrees. Not only do they look neater; they're much less likely to cut and scratch fingers. I never use those square head zips on any of my vehicles. Worth the effort to find and order them.
Old 10-22-2021, 09:12 PM
Discseven's Avatar
Just did look. If this is zip you're suggesting... wonder why these are not sold alongside the "90 degree?"
Karl ~~~
Old 10-23-2021, 07:59 AM
I find them a little harder to cinch tight, but doable. Doesn't explain the difference in marketing?
Old 10-23-2021, 09:16 AM
