-   -   Weltmeister front and rear sway bar installation instructions (http://forums.pelicanparts.com/porsche-911-technical-forum/1105481-weltmeister-front-rear-sway-bar-installation-instructions.html)
Classic 911 10-29-2021 07:20 AM
Hi.
I am looking for installation instructions for 22mm Weltmeister front and rear sway bar system for 911SC.
Hoping that someone here can help.
Cheers
JTL 10-29-2021 08:54 AM
I have the same bars installed on my car and think I kept the instructions for them. Let me take a look this weekend.
Classic 911 10-29-2021 10:35 AM
Thanks a lot JTL that would be super [emoji120][emoji2][emoji120]
Cheers
HarryD 10-29-2021 11:47 AM
The fronts on my 911 are the through the body style. I think yours are under the body. Do you need the early style instructions?
This is for the rear:
Originally Posted by HarryD (Post 4575090)
They connect to modified eccentrics at the springplates.
http://forums.pelicanparts.com/uploa...1238364899.jpg
I am quessing you do not have the install instructions.
http://forums.pelicanparts.com/uploa...1238364935.jpg
http://forums.pelicanparts.com/uploa...1238364957.jpg
Classic 911 10-29-2021 12:06 PM
Thanks a lot HarryD :)
Yes mine are also through the body style ;)
Cheers
HarryD 10-29-2021 01:33 PM
Cheers
Here's the one for the front:
http://forums.pelicanparts.com/uploa...1635543182.jpg
Classic 911 10-29-2021 03:51 PM
Originally Posted by HarryD (Post 11502331)
Thank you very much HarryD [emoji120][emoji2][emoji120]
Is it kind if the same mounting procedure for the front as for the back?
HarryD 10-29-2021 05:22 PM
The drop link (Part N) goes in a tab on your front a arm. The trizngle thing (part R) goes in the hole in your fender wall.
If I add m not mistaken there is discussion here on how to fit a through body sway bar in a later car.
HarryD 10-29-2021 05:32 PM
This post provides more details:
Originally Posted by HarryD (Post 2540222)
HarryD 10-29-2021 05:36 PM
This may be helpful too:
https://www.pelicanparts.com/techarticles/914_front_swaybar/914_front_swaybar.htm
Classic 911 10-30-2021 12:04 AM
This is great help HarryD, again thank you very very much [emoji120][emoji4][emoji120]
Have a great week-end [emoji4]
Cheers
BrakeL8 01-07-2024 04:51 PM
Sorry to bump this thread- but does anyone have torque specs for any of this? Specicially wondering about "N" in the rear the bolt that attached the bar to the droplink but would like to confirm all torque values on my '87 with a full front and rear setup. Thank you!
HarryD 01-07-2024 05:05 PM
When I installed my bars about 20 years ago, I did not torque any bolt. Made them snug and turned just bit more. Never had been an issue.
BrakeL8 01-07-2024 05:43 PM
Great thanks, found 18 ft/lbs for the bar to both mounts but wasn't sure on the others. Will go by this then.
PeteKz 01-07-2024 09:05 PM
15-18 lb-ft is a typical value for M8 bolts.
