Weltmeister front and rear sway bar installation instructions
Hi.
I am looking for installation instructions for 22mm Weltmeister front and rear sway bar system for 911SC. Hoping that someone here can help. Cheers Sent from my iPhone using Tapatalk |
I have the same bars installed on my car and think I kept the instructions for them. Let me take a look this weekend.
Cheers, Jt -84 911 targa |
The fronts on my 911 are the through the body style. I think yours are under the body. Do you need the early style instructions?
This is for the rear:
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 10-29-2021 at 12:51 PM.. |
The drop link (Part N) goes in a tab on your front a arm. The trizngle thing (part R) goes in the hole in your fender wall.
If I add m not mistaken there is discussion here on how to fit a through body sway bar in a later car.
This post provides more details:
This may be helpful too:
https://www.pelicanparts.com/techarticles/914_front_swaybar/914_front_swaybar.htm
This is great help HarryD, again thank you very very much
![]() ![]() Have a great week-end ![]() Cheers Sent from my iPhone using Tapatalk |
Sorry to bump this thread- but does anyone have torque specs for any of this? Specicially wondering about "N" in the rear the bolt that attached the bar to the droplink but would like to confirm all torque values on my '87 with a full front and rear setup. Thank you!
PCA Member since 1988
15-18 lb-ft is a typical value for M8 bolts.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
