Need spark plug recommendation
I am finishing a new engine build and need your recommendation for what spec spark plugs to run in the engine. Some information on build:
3 liter with Stock heads and valve size Aascomotorsports valve springs and retainers Compression ratio 10.5 : 1 Elgin 306/288–102 cams Twin plug MSD AL6 S spec MFI Thanks in advance for your responses Cheers, Dan
DJP; 74 911 3.6 Vram in progress 82 911sc 3.6 street/track 76 930 stock garage queen 84 911 Wide Body 225,000 miles! 72 914 3.0 track; 90 C2 |
The 82/83 911SC Porsche Technical Specs book shows the WR3CC/WR3CP for the Euro engine.
Or the NGK BPR7ES |
Hi.
These two are what I have used on my twin plug 3.2 RSR Short Stroke with 10.3:1 CR: Before: NGK BCP7ES Now: NGK BKR7E V-Power Both of these have the smaller Hex-head you will need for the lower plugs. Cheers |
Thanks for the recommendations!!
It's a 914 ...
Street only?
Also 12mm lower plugs? |
This Engine is going into a 914 that can be driven on the street but is 98% track animal.
No, 14 mm lower. Cheers Dan
DJP; 74 911 3.6 Vram in progress 82 911sc 3.6 street/track 76 930 stock garage queen 84 911 Wide Body 225,000 miles! 72 914 3.0 track; 90 C2 Last edited by dpegan; 11-02-2021 at 01:03 PM.. |
Reiver
With that compression use a cold plug as Porsche recommends.... for the 930-10 w/ 9.8-1 comp that equates to a NGK 7788 BPR 9 ES not the 7.
De Oppresso Liber Strength and Honor 5th Legion |
start with a cold plug.
especially for track . hotter plugs are needed if you idle a lot, do a lot of city driving or if you have carbs,
