Need spark plug recommendation
I am finishing a new engine build and need your recommendation for what spec spark plugs to run in the engine. Some information on build:
3 liter with
Stock heads and valve size
Aascomotorsports valve springs and retainers
Compression ratio 10.5 : 1
Elgin 306/288–102 cams
Twin plug
MSD AL6
S spec MFI
Thanks in advance for your responses
Cheers,
Dan
DJP; 74 911 3.6 Vram in progress
82 911sc 3.6 street/track
76 930 stock garage queen
84 911 Wide Body 225,000 miles!
72 914 3.0 track; 90 C2
Old 10-31-2021, 10:46 PM
Bill Douglas's Avatar
The 82/83 911SC Porsche Technical Specs book shows the WR3CC/WR3CP for the Euro engine.
Or the NGK BPR7ES
Old 10-31-2021, 11:48 PM
Hi.
These two are what I have used on my twin plug 3.2 RSR Short Stroke with 10.3:1 CR:
Before: NGK BCP7ES
Now: NGK BKR7E V-Power
Both of these have the smaller Hex-head you will need for the lower plugs.
Cheers
Old 11-01-2021, 02:57 AM
Thanks for the recommendations!!
Old 11-01-2021, 09:58 AM
It's a 914 ...
stownsen914's Avatar
Street only?
Also 12mm lower plugs?
Old 11-01-2021, 08:37 PM
This Engine is going into a 914 that can be driven on the street but is 98% track animal.
No, 14 mm lower.
Cheers
Dan
Old 11-02-2021, 12:59 PM
Reiver
Reiver's Avatar
With that compression use a cold plug as Porsche recommends.... for the 930-10 w/ 9.8-1 comp that equates to a NGK 7788 BPR 9 ES not the 7.
De Oppresso Liber
Strength and Honor 5th Legion
Old 11-02-2021, 06:52 PM
T77911S's Avatar
start with a cold plug.
especially for track .
hotter plugs are needed if you idle a lot, do a lot of city driving or if you have carbs,
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-04-2021, 07:27 AM
