Indicator query
Hi, I’ve got a 1976 Targa
The indicators work fine but on the dial both lights are permanently lit and when I use the turn stick the wrong side on the dial flashes although the correct lights flash on the outside.
I hope this make sense.
Old 11-15-2021, 01:06 PM
Heck, I’m only 5 not 71!
targa80's Avatar
I posted the below link in another signal indicator thread. If your turn indicators in the tach are not functioning correctly the this link should help you to diagnose the issue. Try swapping the bulb sockets to correct the incorrect turn indicator flashing. The constant illumination of the turn signal indicators can be diagnosed using the attached thread.
Flasher/Hazard Mods on my 80SC
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 11-15-2021, 01:54 PM
targa80's Avatar
This thread below has more info and pictures of the mod to the turn signal relay circuit to fix the turn indicator fault.
https://forums.pelicanparts.com/porsche-911-technical-forum/850904-911-turn-signal-indicator-issue.html?highlight=Turn+signals
Pat Henry
Targa80
Old 11-15-2021, 02:00 PM
