khamul02's Avatar
Cleaning pistons & cylinders?
Before I do this I wanted to double-check. I have read several threads about using an ultrasonic cleaner on pistons and cylinders. The majority say it is ok with dawn dishwashing liquid. Some people say 3 30 minute sessions with a wipe down between works well. My questions are:
Is this in fact safe for nikasil and everything else?
What else should be done after, red scotchbrite on the cylinders? Measurement check? Re-ring and reinstall?
My preference is to take care of this phase myself but is it just safer to send everything off to a machine shop for cleaning and inspection? This engine probably has about 60k on a top-end rebuild.
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 11-02-2021, 06:21 AM
Ultrasonic is fine, but blasting is faster, you can blast tops of pistons and outsides of cylinders. After cleaning use red scotch brite in soapy water. Dry in oven or with compressed air.
Old 11-02-2021, 06:32 AM
khamul02's Avatar
What grit media do you recommend to blast the tops?
Tom Hutchinson
Old 11-02-2021, 07:33 AM
I taped off the ends of the cylinder and bead blasted the outside. Be sure top and bottom surface is well taped off, then just wash ID with hit water, dawn dish soap and a scotch Brite pad.
The pistons and cylinder head combustion chambers I just used aircraft paint stripper, it burns right through all the baked on carbon, and it wipes off with virtually NO scrubbing.
Old 11-02-2021, 07:53 AM
To glass bead the cylinders, I plug both ends with a couple of plastic paint mixing cups. They get a good grip and don't come loose.
206 637 4071
Old 11-02-2021, 08:28 AM
kevingross's Avatar
Vapor blasting.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 11-03-2021, 10:45 AM
Originally Posted by kevingross View Post
Vapor blasting.
Yep, this is the best result I think. A friend has a good setup and he does work for the public and offered me to have a go myself. It was my first time and while it looks decent you can see it's not perfect.
I'm taking them back to get them done by the professional.
The 2 cylinders were bead blasted... then I vapour blasted one for comparison.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 11-04-2021, 02:28 AM
Discseven's Avatar
Careful with media blasting. Can eat through cylinder fins quickly. Got to keep the gun/dispenser moving constantly over fins.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 11-04-2021, 07:02 AM
T77911S's Avatar
i let a machine shop do it.
mainly because I did not have a good way to do it.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-04-2021, 07:20 AM
Never thought of mixing cups, good idea.
Old 11-05-2021, 04:35 AM
probably no good for mixing paint any more.
206 637 4071
Old 11-05-2021, 05:08 PM
